Technical Support, Instructions, Repair Service & Recommendations *New*
Sony KP-51WS500 51 in. Rear Projection Television
Problems with Sony KP-51WS500 51 in. Rear Projection Television?
Ask our Experts
Ask
Find a Solution
Troubleshooting and Support
Solved Problems for Sony KP-51WS500 51 in. Rear Projection Television RSS Feed Post a New Problem
Red lines across screen
My Sony Kp-51WS500 rear projection TV is now showing on the screen, red lines going accross it. Is it fixable
2 Solutions
TV keeps cutting off and it fades blue and...
TV keeps cutting off and it fades blue and green at times
1 Solution
I found a sony kp 51ws500 rear projection
I found a sony kp 51ws500 rear projection tv. The circuitboard containing the buttons found under the screen is missing...
1 Solution
screen goes green then black
Yeah I'm getting the same problem on mine. I turn it on, after a few seconds it flashes green and the screen shuts off....
1 Solution
top and bottom of picture is arched and...
top and bottom of picture is arched and picture is blurry
1 Solution
double and triple picture
The flash focus button isn't lining up all of my colors. I need to know how I can locate the part in the tv that needs...
1 Solution
Unsolved Support Problems
Unsolved Problems for Sony KP-51WS500 51 in. Rear Projection Television RSS Feed Post a New Problem
sony 57 blinks 6 times
I have a sony 57 rear projection tv. 2 out of the 3 boards have been replaced. Still same problem. After reading other...
Post a Solution
color misalignment/ cyan and red
The center appears normal; but surrounding the center the colors are shifted. Red to the left. Cyan to the right Sony...
Post a Solution
blue dots all over
blue dots all over
Post a Solution
I have blue swirly lines across the top of...
I have blue swirly lines across the top of the screen & all objects have a blue shadow
Post a Solution
double picture and flash focus adjusts it...
sony kp-61v90 and the flash focus isnt working well....where is it located and how do i fix it?
Post a Solution
green screen red light flashes 5 times
When I turn on my TV, I get a green screen, red light on front panel flashes flashes 4 time, then screen goes black and...
Post a Solution
kp51ws500 color flickering
This set started fading blue, coming back, fading coming back, then straightening up. Highly intermittant. When it does...
Post a Solution
Tips & Tricks
Post a New Tip
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Screen Size51 inch
Display Capabilities
Aspect Ratio16:9 · 4:3 Enhanced
Image Quality
Velocity Scan ModulationWith VSM
Comb FilterDigital 3-Line
Adjustable Color Temp.With Adjustable Color Temperature
Audio Features
Audio TypeVirtual Surround
Technical Features
Picture in PictureWith PIP
Sleep TimerWith Sleep Timer
Energy Star CompliantEnergy Star Compliant
Connectors
Headphone JackWithout Headphone Jack
Screen Text
Channel LabelsWith Channel Labels
Closed Caption on MuteWith Closed Caption On Mute
Dimensions
Depth24.75 in.
Height51.5 in.
Width47 in.
Weight168 lb.
Warranty
Overall Warranty1 Year
Tube Warranty2 Years
Sony Contact Information
Main support number800-488-7669
Sponsored Links
Describe your problem:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 2826
Experience: I have yrs of experience dealing with many situations.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(407) 952-4048
WE REPAIR ALL BRANDS TV-BIG SCREEN-PLASMA-LCD...
        JR  ELECTRONICS
Prescreened Contractors
Get Matched to Prescreened Home Media Professionals
Category
Zip code
