20 Most Recent Hitachi 51UWX20B 51" Rear Projection Television Questions & Answers
Could be an open internal fuse or spontaneous power supply failure.
Hitachi 51UWX20B... | Answered on Dec 12, 2017
tri-tronics or ecompess parts about 120.00 if they are still available
Hitachi 51UWX20B... | Answered on Dec 13, 2015
If coming up on screen when magic focus is used it is a convergence issue where the magic focus is not working. If that you can ignore it as set has another better way to adjust convergence in the "Decam" mode.
Hitachi 51UWX20B... | Answered on Jun 12, 2012
Typically it is fairly easy to determine weather you need to do a convergence repair or just make an adjustment with your TV's original remote. Take a look at this youtube video to find out which problem you have...
Hitachi 51UWX20B... | Answered on Apr 25, 2012
It is very easy to determine weather if you need to do a convergence repair or just make an adjustment with your TV's original remote. Take a look at this youtube video...
Hope this helps!
if your talking about the sets convergence does not line up and it looks like a 3-D picture than The best advice I can tell you at this point is to go to tvrepairkits.com and order the complete convergence kit for your model of TV set, no need to search and order multiple parts from different sources and pay multiple shipping fees! Go to http://www.tvrepairkits.com/xcart/home.php?partner=larry
The kit comes with original Sanyo STK IC'S , not those cheap aftermarket or china made IC'S full pictorial directions, the thermal paste, resistors, the correct Pico fuses, AND free live on-Line tech assistance in case you run into a problem with the repair. They ship out 2 to 3 day Priority mail, the next day in most cases GOOD LUCK!!!
Larry Dillon.
http://www.fixya.com/support/r3342653-convergence_fix
Convergence board needs repair, google you model # and see if you can purchase a repair kit.
Hitachi 51UWX20B... | Answered on Nov 22, 2011
You need to replace the STK ICs which are Convergence ICs STK392-110 use 120s or 150s
also check the small ohm resistors around ICs . They are Big Black ICs and will have part number on them ,should be located on the Right hand side of Chassis .
Mats Eletronics has Parts 1-800-628-1118 Convergence IC Kit.
Hitachi 51UWX20B... | Answered on Jul 04, 2011
your power supply is out
Hitachi 51UWX20B... | Answered on Jun 09, 2011
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Hitachi 51UWX20B... | Answered on May 18, 2011
  • Screen looks 3D
69189a5.pngSOLUTION
Hitachi 51UWX20B... | Answered on Apr 15, 2011
You have a bad convergence board. You will have to remove the convergence board. If I remember,this board also has the flyback transformer mounted on the same board. It is quite complicated to pull this board. You will need to use different colored permy markers to remember how to reconnect the cables and connectors. The ICs you will replace are the STK-392-110 and STK-392-150. You will resistors that are low ohms (under 10 ohms) at two watts. They may be 1.5, 1.8, 2.2, 2.2, 2.7,3.3,3.9, and 4.7 ohms. For a full detailed instructions and photos see the website,www.TvRepairKits.com. Be sure to have your model number handy and follow the instructions on this website. I have repaired many TVs using this site. Thanks for asking and show all hands of support!
Hitachi 51UWX20B... | Answered on Apr 07, 2011
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Hitachi 51UWX20B... | Answered on Jan 13, 2011
Hitachi 51UWX20B... | Answered on Dec 15, 2010
It is the convergence units themselves in the TV that are failing, that is why they help slightly but can't fully correct the problem. This is major hardware failure for sure, and on this older unit of Hitachi a very common problem. It is repairable but cost prohibitive to do so. You may want to look into just replacing the unit. Let me know though if you really want to attempt the repair yourself.
Thanks
Tim
Hitachi 51UWX20B... | Answered on Oct 06, 2010
Hitachi 51UWX20B 51" Rear Projection Television Logo
64 questions posted
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Televison & Video
Most Popular Question
red will not align up in our hitachi
  • Televison & Video
