Our water stopped dispensing from door. I assume its frozen in the line somewhere but not sure where or how to even find where in the line. and how do I prevent this from happening again?
Its probably frozen inside the door. GE had an issue with this a while back they didnt insulate their doors well enough. If you remove the bottom kickpanel there will be a quick disconnect at the bottom. Remove one side and call for water. If you have water to that point then you know its frozen through the door. You have to thaw the unit out and just try to use the water through the door more frequently. You have to replace the door with the "better insulated" door to actually fix the problem.
Good luck _MJ_
