Question about GE GSH25JSTSS Stainless Steel Side by Side Refrigerator
Water Dispensor The water dispensor just quit working. The light comes on and you can here a small click when i put a glass in there. There is also pressure where the filter is in the refrigerator. I pushed in the little tab and it sprayed all over so I assume there is a problem somewhere between the filter and the nozzle itself. Any suggestions?
Posted by budd0020 on
  • Anonymous Mar 25, 2014
    new filter gave a hiss when plastic ends removed, then put in the slot, when pushed in water spewed, filter will not pop in so that the push tab will pop out
Anonymous
  • 18 Answers
I fixed mine by leaving the light on the dispenser on. It took about 6 hrs, but the little heat from the light bulb was enough to defrost the water line.
Posted on Jan 07, 2008
Anonymous
This just happened to us and I took your suggestion and it worked like a charm! Thank you for saving us over $100 service call!
Posted on Dec 10, 2007
Anonymous
The water line is frozen inside the freezer door. Open the freezer door and take a hair dryer to warm the inside of the feezer door. Check the water dispenser every 5 minutes to see if the line is unfrozen. Water line is ran from the bottom to the waterr dispense unit. Usally take 10-20 minutes to unthaw water line inside of freezer door. Good luck.
Posted on Nov 20, 2007
Water will not come out of the door dispenser
have you replace water filter ..... an easy test go to back of refrigerator where waterline goes int fridge and revers wires for icemaker and water dispensor and now use water dispensor it should put water into icemaker that will tell u that the switch to dispensor is working and you have a bad watervalve needs replacesed
Feb 03, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
The ice dispensor and water dispensor on my GE Profle side by side refrigerator quit working.
Did you check the filter ? If it has been a few years, the filter can be clogged. Also, the water line connection valve may be internally blocked. If it is a tap-valve I suggest you turn it fully closed and then reopen it; this may break free any deposits that have built-up and clog the small opening. But before you reopen the valve, disconnect the line where it attaches to frig and let the first quart of water flow into a container to fluch away any particles before allowing it to flow into frig system.Can also be that the inlet selenoid valve or its wiring connections and switches are not working. You must hear a click sound when you touch the dispensor handle for water. Good luck, Macgivor
Oct 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a G E. modle GSS22UFMD WW .SIDE BY SIDE. I,M NOT GETTING WATER TO DOOR,ICE MAKER. I PUT NEW FILTER IN THAT DID NOT HELP. I UNHOOKED WITERLINE UNDER FRONT DOORS NO WATER IN LINE,WHEN I TAKE WATER...
Did the icemaker and water dispensor quit at the same time ? Your model has the 2 lines coming from the top ( filter ) behind the refrig . One line to the wall water line to filter and the other coming down to the water valve . Do you have the filter bypass piece that came with the refrig ? Use it to test . Remove the back panel . If both stopped at the same time , check the connector that the wires connect to . With 2 connectors on each solenoid , those 3 or 4 wires go to a seperate plug in . Check this plug in . If wireing seems ok , remove the larger tubing from the valve by pushing in on the white ring and pulling the tubing out at the same time . Press the water dispensor , and see if water comes out of the valve . If it does , (you said you disconnected the tubing below the freezer door and no water came out while activating the water dispensor ) then the tank at rhe bottom of the refrig section behind the crispers , is frozen . To thaw , use a hair dryer with the light bulbs in the refrig section , unscrewed slightly . This is only for the water dispensor . For the icemaker , disconnect the smaller tubing , while someone else , turns the icemaker on and off several times to see if the valve momentarily opens each time the icemaker is turned on and off . I think the water valve wiring plug , has something to do with this because I have never found a G E where both quit at the same time without it being that plug ( 2 times ).
Aug 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I changed the filter for the water dispenser and after purging the water for awhile, the dispenser stopped working. What needs to be done to get the water dispenser to work again
Put the old filter back on , if water was fine . You never change filter just because a light comes on telling you to . The change filter light comes on after time or usage of dispensor .( Good way for manufacturers to make extra money ) . Change the filter only when water flow slows from dispensor .
Aug 13, 2009 | Sub-Zero 690 Side by Side Refrigerator
Water dispensor problem (zIss420dmass)
hmm, wonder if the flap is broken inside where the water comes out or the control board is not working properly
Jun 23, 2009 | GE Refrigerators
Trying to repair water dispensor
Check/clean/replace dual water inlet valve/solenoid.
Nov 30, 2008 | Maytag MZD2766GES Side by Side...
Water dispensor does not dispense water. Ice maker works.
you have prime the system air out of the water lines this is easy to do
put a glass big enough to cover water dispensor outlet cause its going to project water out at you press and hold button till water starts to run smooth
these fridges will spit water at you when you prime the system at first cause theres air blockage in lines
May 20, 2008 | Frigidaire FRS3R5EMB Side by Side...
GE GSH25JSTSS Stainless Steel Side by Side Refrigerator Logo
111 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Mike McBirney
Level 1 Expert
gbob59
