Washing Machines Logo
Posted on Feb 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I stop or reduce the front l washer from vibrating so much
How do I stop or reduce the front load washer from vibrating so much
Anonymous
Level 2:
New Friend:
  • Expert 90 Answers
  • Posted on Feb 04, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
90
Questions
0
Helped
33326
Points
243
Hi
The machine is not balanced on the floor well.... the 4 stands on which the machine rests have adjustable screws... You will need to fasten or loosen the nuts that will adjust the height of the legs on which the machine rests.... all the 4 legs need to be firmly on the floor .... If one is too high then the machine rocks on its side...
Regards
Berry
Spin cycle extra loud
Good Morning Friend,
I understand that the spin cycle is extra loud in your Frigidaire washer, model# GLWS1233A. I also see that you have grease splattering inside the front and right side panels at the bottom of your appliance.
Certain amounts of clunking or gear sounds are normal in a heavy-duty washer.
If you are hearing any rattling or clanking sounds, there could either be foreign objects such as coins or it could be belt buckles or metal fasteners.
If you are hearing a squealing sound, your washer could be overloaded. Stop the cycle and reduce the load.
Thumping sounds usually means this is a heavy wash load. This is a usual sound, but if it continues, your washer could be out of balance. Stop the cycle and redistribute the wash load.
If you are receiving a vibrating sound, there are a couple of things that could be causing this.
    1)Your washer is not resting firmly on the floor. Make sure your washer is resting firmly on the ground as well as level. You will want to make sure that it is level from front to back, side to side, as well as from corner to corner.
    2)The wash load could be out of balance. Stop your washer and rearrange the wash load.
    With you receiving grease splatters, depending on how much and how often, I suggest contacting your local authorized technician for assistance. They will be able to diagnose your washer as well as determine where the grease is coming from. Hope this is helpful.
    -Best Regards-
    WP
Vibrates when it spins
Here are a few quick facts on washing machine vibration.
  1. All washing machines and dryer vibrate. Dryers usually have less vibration than washers because the load is only wet clothes (as opposed to a drum of water and clothes). Front loading washing machines cause high frequency vertical oscillation while top loading washers usually have horizontal oscillation.
  2. Almost all front loading washing machines are not recommended for use on standard joist-construction floors (most common floor type, compared to a concrete slab sub-floor). Manufactures like GE, LG, Maytag, Samsung, Whirlpool, Kenmore, Bosch and more, all recommend installing a pad like Silent Feet under the washing machine to absorb the vibration.
  3. The only alternative to using Silent Feet pads to prevent structural damage is costly upgrading of the sub-floor. This usually involves adding a second layer of plywood sub-floor and adding sister boards to the rafters that support the floor. But even this won't reduce the amount of vibration noise that you hear. Sub-floor upgrades can cost thousands of dollars.
  4. Vibration can also cause appliance "walking" (unwanted movement) usually during the spin cycle. Simply installing a pad designed to prevent walking can solve this problem and mean that you'll never have to reposition your washer after every load again. Both Original Silent Feet and Anti-Walk Silent Feet prevent walking, however for washers that move a lot or stacked units it is recommended that you install Anti-Walk Silent Feet for the best results.
You were not specific in either type or model. I hope the above information helps. Also, the size of the loads plays a great part in how a machine functions. have a nice day
You wer
LG WM3987HW Washer Spining very wild
I've just uploaded a service manual.
relevant info pasted below: --
Regulate a specific spin speed that generates excessive vibration and noise as follows:
1) Put an unbalance part (rubber) inside of the drum.
(this is a special weight that service people use. It clips into the drum. If you don't have it, throw in about 4 to 6lbs of damp laundry.)
2) Start the QC test mode (Refer to section 7-2).
7-2 says turn the washer off, then press 'spin speed' and 'soil level' at the exact same time. Then, while holding both buttons, press power to start "QC test mode"
3) Press Delay Wash button, then ' tst ' is displayed on lcd
4) Press the Spin Speed button repeatedly to select Extra High.
5) Press the Quick Cycle button, the spin speed is displayed.
6) Press the Start/Pause button.
7) Press the Beeper button repeatedly to set spin speed (600, 800, 1000, 1200 rpm) and check if there is vibration
and noise.
8) If there is no vibration and noise, increase the spin speed by pressing Beeper button.
9) If there is vibration and noise, rotate the Cycle selector knob clockwise to reduce the Spin Speed (reduce by 50
and 100 rpm). In case of 600 rpm, it can not reduce the spin speed.
10) If vibration and noise are reduced, press the Quick Cycle button to store (2 beep sounds).
* If you want to return to factory default spin speed setting, repeat above steps except step 9)
My Frigidaire Affinity dryer has started vibrating more and more during operation. Is the motor going bad or is there another problem?
Hi
Try the following to reduce the noise--
Washer is not resting firmly on floor. Move washer so it rests firmly on floor. Adjust leveling legs. NOTE: Some shaking of the washer is normal without moving across the floor.
• Shipping bolts and foam blocks have not been removed during installation. Check out the installation instructions for removing shipping bolts and foam blocks.
• Wash load unevenly distributed in drum. Stop washer and rearrange wash load.
Please post back for any further assistance.
Daniel
2answers
On the spin cycle my miele walks acrossed the floor
make sure you loads are balanced, put heaviest clothes in first... if you can rock it by hand then the legs are not adjusted properly. If you stand 2 feet away from front of machine, jump up and down and see it move the floor is soft and you need 2 sheets of plywood to make 1 1/2 inches put under the machine
Whilrpool duet front loader
hi valeriekate...The washer must be level and properly
installed, and the nuts should be tightened against the
washer cabinet. The sound may also be from metal snaps, buckles or
zippers touching the washer drum. The washer should also be installed on a sturdy and solid floor. Noise and vibration may be reduced by placing
a piece of ¾ in plywood underneath your washer. Also check if the washer was grounded when installed.it will reduce the risk of electical shock.be sure not to use an adapter or extension cord..hope this helps..thanks for using fixya...
2answers
Vibration during spin cycle - "walking" across floor
dear sir/mam
please check the floor level of your washer by using the spirit level,if there is difference please adjust the level by screwing the legs of the washer,then vibration will be stopped.
3helpful
Whirlpool washing machine
Welcome hendrik,
You said, jumping around during spin cycle
How old is your GHW9150 washer?
Usually it is overload or load unbalanced due to uneven load.You must stop the machine and re-distribute the load and or weight!
Here are some Whirlpool reasons for you.
But if nothing helps you may have a mechanical problem to be serviced!
Try these ideas first!
Is the load balanced?
A single or bulky item may cause imbalance. Add more items
or redistribute the load.
Washer makes noise or vibrates
Is the washer level?
The washer must be level. The four feet should be properly
washer cabinet.
As water is drained from the washer, you may hear air being
pulled through the pump. This happens during the end of
draining. It is normal.
Are you washing items with metal snaps, buckles or zippers?
You may hear metal items touching the washer drum. This is
normal.
Is washer installed on a sturdy and solid floor?
Refer to the “Installation Instructions” for flooring
requirements. Noise and vibration may be reduced by placing
a piece of ¾" (19.1 mm) plywood underneath your washer.
The plywood may extend underneath both washer and dryer
to keep them at equal heights.
Let me know If you have any questions and what happens!!!
Huuum
Please remember to leave a rating!
2answers
Kenmore HE2 Front Load Washer
is it level ? i had to level mine then i had a nut that come off had to put that back on on i am all set
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
