Macbook pro recognizes external monitor but the monitor is not recognizes the macbook. and the monitor goes right to sleep so i can't figure out how to adjust settings on the monitor. monitor is NEC multisync LCD 1700M+
SOURCE: I have a NEC Multisync
Get into BIOS > Got to Power management > choose S1 & S3 as power management scheme
SOURCE: Problem with an NEC MultiSync 1550V 15" LCD
The power supply section may be failed, or there may be a short on one of the boards causing the monitor to cycle through the protect mode.
Jerry G.
SOURCE: nec multisync lcd 2080ux no raster no power indicator light.
If u a tech, try checking the PSU of the monitor for blown fuse or dead driver element ( typically a FET, Power transistor or an Hybrid chip) . U need to take the monitor apart, if unfamiliar, get it to a service tech.
SOURCE: NEC MultiSync lcd 2010 monitor blank screen
This is the common bad capacitor problem. The caps have died inside, and they can be replaced. If you have basic electronics skills, you can go in, order replacement caps, and unsolder and resolder. If you can't do it yourself, you can take it into a shop.
Here is a link to the Cap plague that explains what happens in detail. But I repair these all the time with that symptom.
http://en.wikipedia.org/wiki/Capacitor_plague
SOURCE: touch system not working NEC multisync 1550v
You have to install the nec driver for this monitor. I have the same monitor. Im looking for the driver now. There are 2 versions of this monitor with the same model # . You will need to find the driver to the touchscreen model.
