FixYa.com
NEC MultiSync 1770NX  17" LCD Monitor
All Products > NEC > Monitors
Problems with NEC MultiSync 1770NX 17" LCD Monitor?
Search inside NEC MultiSync 1770NX 17" LCD Monitor Knowledgebase
Troubleshooting and Support
Solved Problems for NEC MultiSync 1770NX  17" LCD Monitor RSS Feed Post a New Problem
NEC 1770 monitor
How do I keep the annoying resolution window from popping up. I am tired of pushing menu/exit.
1 Solution
Monitor not coming on at all
Hi there, I have just purchased this computer from a very trusted source and setting it up was straightforward until I...
1 Solution
samsung SynsMaster 939B
Have two of the above monitors. Had to discuss my computer for repairs. when it was turned on both monitors would turn...
1 Solution
HI!
i have read ur porblem regarding the monitor one.. how did u fix it.. or it's still the same.. pls help me if u hav...
1 Solution
S700 Compaq Monitor turned off...
Hi, My problem is my monitor turned black while im using it, but the power button remained on green light. What is the...
1 Solution
monitor won't come on after unplugging for...
Help! We had a storm last night and we shut down and unplugged the computers. Now the monitor won't come on. The green...
1 Solution
duel monitor
i have two monitors that i would like to use,i have one connected to my nvidea grathix card which i use but when i plug...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for NEC MultiSync 1770NX  17" LCD Monitor RSS Feed Post a New Problem
XBox 360
Hey, I'm trying to use my NEC monitor en lieu of the TV for my Xbox 360. While the image is certainly clearer/sharper,...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Aspect Ratio5:4 (Regular)
Size17"
Color Depth24-bit (16.7M colors)
Contrast Ratio500:1
Brightness250 cd/m
Max. Resolution1280 x 1024
Dot Pitch.264 mm
Monitor TypeFlat Panel LCD TFT (Active Matrix)
Response Time12 ms
Viewable Picture Size17 in.
Technical Features
Form FactorDesktop
Regulatory ApprovalISO 13406-2 (Pixel defect guidelines)
Digital Video Input StandardDVI-D
Synchronization Range - Horizontal31.5 - 81 kHz
Max. Viewing Angle - Horizontal160
Max. Viewing Angle - Vertical160
Native (Recommended) Resolution1280 x 1024
Resolutions supported1280 x 1024 · 800 x 600 · 640 x 480 · 1024 x 768 · 832 x 624 · 1152 x 870 · 720 x 400
Synchronization Range - Vertical56 - 75 Hz
Dimensions
Depth2.3 in.
Height12.5 in.
Width14.4 in.
Weight9.5 lb.
Warranty
Warranty3 Years
NEC Contact Information
Main support number1-800-338-9549
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
