20 Most Recent NEC MultiSync 1920NX 19" LCD Monitor Questions & Answers
CRT and LCD will look different when compared side by side. Is your CRT calibrated, or are they right in the sense that they are what you are used to? Also Anyway, you can adjust the colors and light levels from the menu on your screen, and depending on your operating system and graphics adapter you should be able to make adjustments there, too. For windows XP, right click your desktop and select properties->Settings->Advanced. There might be a color management tab. Also, there might be software to help you do this already installed. Look for a program group with the name of your Graphics adapter manufacturer. Very often ATI or nVidia. A few resources to help calibrate: http://desktoppub.about.com/od/visualmonitor/Visual_Monitor_Calibration_Tests.htm http://desktoppub.about.com/od/visualmonitor/Visual_Monitor_Calibration_Tests.htm
NEC MultiSync... | Answered on Mar 20, 2013
click start control panel,display,desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps you
NEC MultiSync... | Answered on Oct 05, 2011
Hi, First degauss or reset the monitor. you can select auto reset. Check the resolution setting and colour quality. check the graphics manager from motherboard display properties option. reset it properly. If it doesn't solve your problem then you have to repair the PCB of the monitor.
NEC MultiSync... | Answered on Sep 12, 2011
it is stated that it has vga input.
what are you trying to use it for?
if you are trying to use the dvi input and only have a a vga output on your computer you need a vga to dvi adapter
NEC MultiSync... | Answered on Sep 06, 2010
the monitor is on its way out, but you could adjust the brightness and confirm the power going in
NEC MultiSync... | Answered on Mar 27, 2010
check for magnetic fields around the monitor or else try degaussing the same or else replace ....
NEC MultiSync... | Answered on Feb 27, 2010
backlight may be going. if color is reddish or pinkish tinge. backlight is part of lcd glass itself, can be repaired, but not many shops repair them. can also buy replacement lcd glass for $100 ro so.
NEC MultiSync... | Answered on Aug 26, 2007
connector problems
NEC MultiSync... | Answered on Mar 26, 2017
Some monitors do no come with built in speakers and a sound system much be purchased to have sound from pc.
NEC MultiSync... | Answered on Nov 06, 2013
check the vga cable which get loose connection then the signal from pc not recognized.
NEC MultiSync... | Answered on Dec 25, 2012
NEC MultiSync 1920NX 19" LCD Monitor Logo
24 questions posted
Top NEC Computers & Internet Experts
Ekse
Steven Wander
Steven Wander
Thomas F. Schneider
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
MultiSync NEC
  • MultiSync NEC
Most Popular Question
monitor nec multisync lcd
  • Computers & Internet
