Depending on the model you have it can be either or.
if you can lean the machine back and take a llok under neath you might be able to see the motor and the drain pump might be attached to the front of the motor. look just behind the motor and you should see a black rubber piece with two white plastic pieces this is a drive coupler and if it is broken then you need to replace it
How would I know if the machine is direct drive or belt driven if you did not give a Name and model or years old ?? Get back to me with this info and I give you an answer. Macgivor
