My lg washer is giving me fits. a 55 min cycle takes almost 2 hours to complete. also if i try to use quick cycle it starts then a few mins later the display shows lE and it doesn;t go any further. the clothes are soaking wet and aren't clean. is there something i can replace to get it back on track? LG front load wm1814cw.
IE is Inlet Error. Turn off the water valves behind the washer and remove the hoses from the machine end. Look inside the spot the hoses were attached to, and use a plier to pull out the screen and clean it out. (probably only need to do the cold side) Re-instert screen(s), re-attach hoses, and turn valves back on. (Also, make sure hoses are not kinked behind machine.) Times displayed are estimates, and vary due to water fill rates, and load type and size. In your case, the water fill rate is the problem.
