GE Profile Stainless Bottom-Freezer Refrigerator with Internal Dispenser 22.2 Cu. Ft. - PFS22SIS Logo
craig griswold Posted on Jan 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Clicking noise hello, my refrigerator stop working and have notice a clicking noise coming the bottom.. I have pulled the bottom cover from the back side and determine the clicking noise is coming from (what looks to be a solenoid.)
Anonymous
Level 3:
  • Master 1,891 Answers
  • Posted on Jan 19, 2010
Anonymous
Master
Level 3:
Answers
1891
Questions
0
Helped
409475
Points
5205
Clicking is propably the main board . it is covered by a 5 x 8 plate . remove it and if it smells like burn smell . the board has failed . and you can here the clicking better when its un covered.. mm
What makes the front center where the doors meet on my side by side Roper refrigerator get got to the touch?
Easy. A defrost on the old fridge to keep the doors from icing up. Don't worry be happy.
Maytag side by side msd2572ves02 not working and clicking noise
That clicking sound is the compressor trying to start. Pull off the lower back cover, so you can access the compressor (located underneath the fridge) and carefully remove the cover. There you will see a set of contacts where the clicking is coming from. Having the brand and model number, order a new compressor start kit and replace the old one. This will solve your problem.
3helpful
MODEL# ARB2557CSL STARTED MKING CLKING NOISE TWO
Hello, this problem is going to be with the relay on the compressor or the compressor. Pull the refrigerator out and remove the bottom panel off the lower rear of the appliance. Behind the panel you will see the compressor. On the side of the compressor you will see the relay cover. remove the cover then pull the wire harness off. next give the relay a tug and it should pull off. Once you have the relay in your hand give it a shake. if the relay rattles then your problem is the relay. If the relay does not rattle then the problem is with the compressor. You should call a service guy. If you have any additional questions please feel free to comment. Mike
Maytag refrigerator clicking noise and stopped working
either inside fan out of alignment or defrost timer could be bad
4helpful
Whisling noise coming out of inside the refrigerator. Louder when freezer door is open. maybe ice maker area?
The whistling is caused by the air circulating fan located just behind the light. It is easily accessed by removing the light cover and the two small hex screws above the light. To stop the whistling I simply turned the freezer off and pulled the fan cover out slightly to reveal the fan blades. I then pushed the blades down, toward the bottom of the until the blades stopped and i could feel the shaft slightly protruding from the top of the blades. Repositioning the blade has stopped the incessant whistling. Hope this helps!
1helpful
2answers
Refrigerator sounds like frogs croaking
it may have a fan in the refrigerator at the back wall were you pull the draw out
10helpful
2answers
Clicking noise coming from whirlpool refrigerator
The clicking sound is a relay called PTC relay. You need to replace it. First be sure to unplug frig. Remove the cardboard cover that covers most backs of the frig units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken
Freezer not working
sounds like the clicking noise could be the overload on the compressor. pull off grill cover on bottom front of refrigerator check to see if condenser coil if blocked with lint and dust if it is clean it throughly it could cause the compressor to overheat and cause the refrigerator to thaw and the overlaod to make a clicking noise. hope this helps you out
How long a period of time have you noticed this noise? If it just started and the refrigerator just stopped it could have entered its defrost cycle. When the defrost heaters come on you may hear the heat causing some expansion. After a few minutes(18-22) the defrost cycle ends and the refrigerator will restart.
2answers
Relay clicking, not cooling either side
check you paperwork , and manual. sounds like a compressor issue, which "should" be covered by 5 year manufacture warr. reason i say "should" is hte warr's all changed jan1/06. only one year form there . but check your manual itll have the warr info in it
Top Refrigerators Experts
vince
Johnny 1000
