Troubleshooting & Support
Hot Topics:
- temperature
- model
- service manual
- pfs22sisbss
- noise
- freezing
- pfs22sisass
- water
- door handle off
- door handle
- ice maker
- reset temp
- h300 relay kia...
- leak
- refridgerator
- cold
- making noise
- display
- check condenser...
- fridge
- power
- ice
- clean coils
- board
- control board
- vibrating saab...
- coils
- compressor
- problems alarm
- Refrigerator
- View All »
Problems & Solutions
Freezer working fine. Have water
Hi, Sounds like you have a defrost problem since the freezer side is working okay . It probably is not blowing cold air into the...
MY refrigerator is making a
That sounds tike the inside fan needs to be replaced.
Model # PDS22SFSBKSS Bottom Freezer. Its making a
Hi you need to replace the main motherboard, depending on the age you should call GE if they service your area they will discount the cost...
My refridgerator was not working because of a
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter Sounds as if either your display board is bad or the Mother Board. Take...
GE profile bottom freezer fridge smells (milk in...
We have the exact same problem! Did anything work??
GE Profile stopped getting cold. Can hear motor go
It seems that the starting relay is still good and the capacitor may have gone bad. Replace the capacitor.
Refrigerator is not cooling, freezer stays @ or
Thermisters have gone bad causing the damper to the fresh food section not to open,and or the freezer fan motor is not working.
GE profile bottom freezer unit
Hi, Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling Refrigerator...
Fridge is making a clicking
This is compresso starting problem. What you hear is the relay contact which is on and off and can stay on. You need to check also the...
Fridge not cold
Check your Model # and Ser#. Probably your Motherboard and condenser fan board. No help from GE but file a complaint 1-800-386-1215. Board #...
Hi, we just purchased an 5 year old GE profile
The buzz is most likely coming from the water valve that feeds the ice maker. If the ice maker is not being used the buzz will continue...
refigerator is not cooling properly. Temp
Refrigerator or freezer is not cold enough check this part: * Check the temperature setting * Assure that there is enough room...
If a refrigerator lays on its back during
Hello there : I will have to start out with a question for you after you had it laying down for the 1 hr did you leave it set for the...
When you change the temperature of either the
When you adjust temp settings you will need to wait a minimum of 24 hours for refrigeration system to stabilize, so make only 1 adjustment...
Freezer is too cold, fridge isn't cold enough.
Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to...
See all GE Profile Stainless Bottom-Freezer Refrigerator Solutions
Unsolved Problems
plastic hook on left French door ge profile...
We ordered a hook from GE but it does not match the one that broke. Problem is the door is often slightly open and we...
ge profile noise like working really hard. Fan
Sounds as though a plane is taking off. Like the fan is really working hard. It was fixed once but they say it is...
LG 2 door flidge freezer makes ticking sound and...
LG fridge (model GR-L227STG) is about 4 years old. Ice dispenser light suddenly started flashing and there is a ticking...
My condenser fan is not working
PFS22SISBSS. I changed the condenser fan motor and the control board and it is still not working. What should I do.
Mod#pgss5nfxcss Ice maker not filling with water...
Need set of prints to trace with
Locating coils?
Where is the access located to clean coils? Model # PDS18SBMARS
Owners Manual
Where is the access to the coils located to clean?
See all GE Profile Stainless Bottom-Freezer Refrigerator Problems
Manuals & Guides
TopDo you have a manual for GE Profile Stainless Bottom-Freezer Refrigerator with Internal Dispenser 22.2 Cu. Ft. - PFS22SIS? - Upload it to FixYa!
Upload a manual for GE Profile Stainless Bottom-Freezer Refrigerator with Internal Dispenser 22.2 Cu. Ft. - PFS22SIS
What's your problem?
Fix-O-Meter
21,996
21,996 people have viewed this product
- 359 people asked about this product.
- 89 people found solutions for this product.
- 8 people have added this product.
General Safety...
Pins on the...
How to fix your...
