OUT OF NO WERE, DVD PLAYER QUIT !
UNIT STOPPED WORKING ! COMPLETELY QUIT EXCEPT FOR A SMALL QUICK BLINK OF LIGHT WHEN A CONTROL BUTTON IS PRESSED ON EITHER THE REMOTE OR ON THE UNIT ITSELF.
tHERE IS A DVD STUCK INSIDE BUT UNIT WILL NOT EJECT !
ALL PLUGS AND WIRING ARE FINE. IS THERE A MANUAL RESET OR CODE ? YOU TELL ME PLEASE ?
THANK YOU
DAVID
For a Toshiba SDK740SU, to remove a stuck disc:
1. Remove the top and front cabinet cover;
2. once exposed, slide/move the Rack Loading (white) towards the right with a sturdy instrument such as a common screwdriver;
3. draw the tray out
Please refer to image below:
The only possible easy user workable reset is to unplug the unit for quite some time.
Should the above be not corrective, pls post back whether you have the 740SU or the 740SUA version.
Hope this be of some help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kindest regards.
Pull up older posts.
You can gather all details.
Sometimes, click open the adverts' by the side and bottom of each post
might give you more details.
my also relatively new dvd player will not turn on but the red light is on under the power button how do i fix this problem. Koss unit will not turn on/off with button or remote?
I had the same problem. I was pleasantly surprised to find that the whole unit came back to life once I had removed the two discs that were stuck inside. Thanks for the suggestion!
