Canon PIXMA  MP510 All-In-One InkJet Printer Logo
Posted on Jan 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The yellow lamp is flashing and printer dosn't work .My printer is pixma mp510 canon
Anonymous
Level 3:
  • Master 1,219 Answers
  • Posted on Jan 12, 2010
Anonymous
Master
Level 3:
Answers
1219
Questions
Helped
673834
Points
2880
How many times does it blink... 2, 3, 12....
2 times Carriage error [5100] An error occurred in the carriage encoder signal. - Carriage unit (QM2-3753)
- Timing **** film (QC1-9542)
- Logic board (QM2-3827)
- Carriage motor (QM2-3872)
3 times Line feed error [6000] An error occurred in the LF encoder signal. - Timing sensor unit (QM2-3878)
- Timing **** disk film (QC1-9597)
- Feed roller (QL2-1407)
- Paper feed motor (QM2-3873)
4 times Purge cam
sensor error
[5C00] An error occurred in the purge unit. - Purge unit (QM2-3754)
5 times ASF (cam)
sensor error
[5700] This error takes place when feeding paper from the
ASF after an error occurred in the ASF cam sensor.
- Sheet feed unit (QM2-3762)
- ASF_PE sensor board (QM2-3877)
6 times Internal
temperature
error
[5400] The internal temperature is not proper. - Logic board (QM2-3827)
7 times Ink absorber
full
[5B00,
5B10,
5B01,
5B11]
The ink absorber is full.
Error codes:
Overseas:
5B00: Main ink absorber
5B10: Borderless-print ink absorber
Japan:
5B01: Main ink absorber
- Ink absorber kit (QY5-0178)
1-5
Note: Before replacement of the logic board ***'y, check the ink absorber counter value (by service test print or EEPROM information
print). If the counter value is 7% or more, also replace the ink absorber kit (QY5-0178) when replacing the logic board ***'y, or
register the current ink absorber counter value to the replaced new logic board instead. [See 3-3. Adjustment / Settings, (9)
Service mode, for details.]
2-3. Other Error Messages
5B11: Borderless-print ink absorber
8 times Print head
temperature
rise error
[5200] The print head temperature exceeded the specified
value.
- Print head (QY6-0070)
9 times EEPROM
error
[6800] A problem occurred in writing to the EEPROM. - Logic board (QM2-3827)
10 times VH monitor
error
[B200] The internal temperature exceeded the specified
value.
12 times PG position
error
[5C10] An error occurred in the PG motor during purging
operation.
15 times USB Host
VBUS
overcurrent
[9000] The USB Host VBUS is overloaded. - Logic board (QM2-3827)
19 times Ink tank
position sensor
error
[6502] None of the ink tank position is detected. - Spur base unit (QM2-3750)
20 times Other
hardware error
[6500] The PCI bus error is detected by the ASIC. - Logic board (QM2-3827)
22 times Scanner home
position error
[5010] The scanner unit cannot detect the home position, or
the scanner unit warming-up is not performed
properly at power-on.
On the LCD, "Scanner is not operating correctly." is
displayed.
- Scanner unit (QM2-3775)
Alarm and Power
LEDs lit
ROM error,
RAM error
A flash ROM or RAM checksum error occurred at
hard-power-on.
5 Related Answers
Anonymous
  • 52 Answers
  • Posted on Jan 09, 2008
SOURCE: OS X 10.5 Leopard & Canon PIXMA MP510
hi i am a certified Canon4.gif repair tech for this printer. if you follow the link below this will take you to Canons support site where you can download the software for your printer. hope this helps
http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Anonymous
  • 26 Answers
  • Posted on May 21, 2007
SOURCE: RECOGNITION OF GENUINE CANON INK CARTRIDGE
Who ever told you that you cannot take out an ink cartridge and put it back is an idiot to say the least, I bet its your "ink man". Of couse you can take out your ink cartridge and put it back. Mind you the head of the cartridge might be faulty, take it back to the person who sold it to you and get it replaced. If it is a genuine cartrige Canon will replace it for him.
Anonymous
  • 619 Answers
  • Posted on Jan 22, 2008
SOURCE: CANON MP510 NOT WORKING
Hi, does your printer have enough ink? If enough still blink. need to down load a reseter from canon web site inquire if they have free download printer reseter.
Anonymous
  • 2306 Answers
  • Posted on Jun 19, 2009
SOURCE: Canon MP980 All in one printer - Error 6000
Error 6000 tells you that the paper feed roller is not turning, check for any foreign oblects in the paper path, a flashlight and small mirror is the best way to look.
Anonymous
  • Posted on Dec 29, 2009
SOURCE: error b200, green and orange lamp flash
orange light blinking
Canon PIXMA MP510 problem with j feed
Is mechanical problems,gears blocated,you must be remove the covers and look attent the transport drive mechanism components.
6helpful
I have canon MP510 printer 4 years old not over used. Was ok earlier in the day, now green and yellow lights flashing and paper feed light not lit. shows B200 error message. should I just buy a new...
The error B200 is an internal overheat error. It is usually associated with an overheating print head. The fault can be with the print head,carriage or even the logic board. You will not be able to locate the trouble unless those 3 items are replaced in that sequence. in other words SCRAP it as the costs will be enormous.
srri
1helpful
Canon MP510 wont print. Error message B300 or
May I know the exact error messages in the printer screen. If it's green and yellow lights that are flashing you need to push more the two cartridges that you replace....also try to clean it using the printer program installed in your computer....good luck and hope it will help....
E2 power lamp flashes green and alarm lamp flashes yellow
compatible cartridges don't work i have 180 pixma canon and the alarm light yellow
no dessapear and the printer no work
what i can do
than you
JUan
4answers
Install canon pixma mp510 - don't have disks
I have lost the installation Cd to this printer too. How to install without the cd? I am using windows xp
10helpful
3answers
4answers
Canon MP510 wont recognise cartridges
Using replacement cartridges that come without a chip seems to be the problem I had with the Canon Pixma 510 printer they are cheaper
but if they do not show the ink levels then its inconvienent so I have but Canon products with a chip and they work perfectly.
old marine
old marine
ZJ Limited
ZJ Limited
