Samsung HCL4715W 47" Rear Projection Television Logo
Posted on Feb 03, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
More Convergence Issues
Red, Green, and Blue images were mis-aligned, was unable to align manually (could not control red, and green only in "y" direction). I replaced both convergence ICs, and still the same problem remains. When manually adjusting the color grid, I am unable to adjust the red grid, and can only adjust the green grid in the "y" direction. And when I turn the red grid off for adjustment, there is still a wavy red line on the top of the screen. I did notice that "RR402S" and "RR471S" look like they are both fried, but I assumed since they are SEMI variable resistors, they were part of the volume control circuit? Am I wrong? Could these components be part of the convergence circuit? Any help would be much appreciated, this sorry tv has got me at my wit's end.
  • aufanincinci Feb 03, 2008
    Thanks for the quick feedback, I'll go ahead and order replacement parts and get back to you.
Sonny Berry
Level 3:
  • Samsung Master 8,617 Answers
  • Posted on Feb 03, 2008
Sonny Berry
Samsung Master
Level 3:
Answers
8617
Questions
Helped
1723471
Points
23750
They are definitely a part of the convergence circuits. A variable resistor increases resistance as they warm up. So excessive heat destroys their capacity to perform as was designed and you will continue to have issues until all components are within 5% tolerance levels. Hope this helps. let me know if you need anything more for information.
3answers
I have red and green shadows. I tried using the Converge Red/Blue and Multipoint Red/Blue functions as described in the manual but neither worked
The tv 100% have convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv have a dead convergence board,the 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be change to fix the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Convergence adjustment aligns red and blue picture tubes to align with fixed green tube. Green image appears to skewed (possibly out of focus) in one direction making it impossible to get red and blue...
Ur tv convergence are dead.U know how to solders?Must replaced the 2 STK convergence ICS,some or all it resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
2answers
RED Convergence Alignment issue
Replace both STK392-110 Convergence IC's with Toshiba or Sanyo quality................No cheap IC's !!!......................T.
1helpful
Convergence ICs
the green is half controlled by half of each of the convergence Ics meaning green horizontal is controled along with the red and green vertcal is controlled along with the blue Ics. So if you have replaced both Convergencs ICs the problem is most likely a resistor that is in the green circuit. You will need a schematic to locate which resistors are in the green vertical and horizontal convergence circuit
Red is off to the right while blue and green light are in sync
Convergence alignment issues are common to all rear projection
TV's....Repair requires replacement of STK IC's on large heatsink.
After repair, alignment often returns to normal......T.
2answers
Toshiba 57h82
your convergence amp ic's./if you want to cheat/align the other two colors and manualy move the green yoke rings on the green picture tube neck so the green cross aligns with the red and blue.,they shuold form white when all three are aligned,on top of each other.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
