our sumsung rear projection tv colour has gone pink at the top and green at the bottom, with the...
(More)
our sumsung rear projection tv colour has gone pink at the top and green at the bottom, with the bottom half normal. does this mean the tv is on its way out?
No power to my SamsungHCL4715 W Rear Projection TV. for a brief time the red LED would flash three...
(More)
No power to my SamsungHCL4715 W Rear Projection TV. for a brief time the red LED would flash three times and quickly turn off. The picture would not come up at all before it powered down. Now there is no power at all. Is there any fuses? Is there a reset? any known issues related the the type of issue I am having. And finally, Is it even worth fixing this TV which was manufactured in 2001?
my crt tv have fait dall pictures requre me close windows for a clear vewing ihave tried to even...
(More)
my crt tv have fait dall pictures requre me close windows for a clear vewing ihave tried to even increase the contrast and brightness in vain please asist me
The tv wont start up at all. It makes a clicking sound like it is trying to start. Power is good....
(More)
The tv wont start up at all. It makes a clicking sound like it is trying to start. Power is good. Cable connection is good.
I have a samsung 4715w, The tv now shuts off after 3-4 secs after turning on. I hear it power up,...
(More)
I have a samsung 4715w, The tv now shuts off after 3-4 secs after turning on. I hear it power up, then the sound comes on for a sec, no picture then it shuts down automatically. I got a new convergence board , but the replacement board does not have a plug where the old one had one. It does however have the main plug at bottom of board. Samsung says the AA95-01799g is the right board replacement.
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D...
written by Ecollier2012
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
