To remove the sides, there is one torx screw on the upper side on the rear of both covers ,and one torx screw inside the front upper paper path. You open the paper path door, as if you were removing a jam, then you will see the screws on the upper top of the cover.
Remove those screws and then go to the side of the machine and pull up and out of the covers to release the tabs.
The top, I am not sure you have to remove, but where you load the ink. there are just some tabs that hold the ink loader in, You use a thin blade screwdriver to release those tabs and then lift the ink loader out. There are 2 connectors to the ink loader to unplug.
