20 Most Recent
Xerox Phaser 6125 Laser Printer Questions & Answers
I have a Xerox Phaser
042-372 K Mode Sol Error
Restart Printer
Error 042-372
Restart Printer
Each color has it's own solenoid. the K solenoid is the one for the black ink. It may be that toner has clogged the sensor on the inside right wall of the printer. Sensor hole is a small opening and K is the first hole. Clean it with a cotton swab and alcohol. clean any loose toner also. If this does not take care of it. The sensor board or the solenoid itself needs to be replaced.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Laser Error Error message 061-370 for Xerox Phaser 6125
From the service manual:
Troubleshooting Procedure Table
Step Actions and Questions Yes No
1 Check the Laser Unit for correct
installation.
Is the Laser Unit correctly installed?
Go to step 3. Reinstall the
Laser Unit. Go
to step 2.
2 Cycle the power.
Does the error still occur?
Go to step 3. Complete.
3 Check the wiring harness connectors
P/J40, P/J41, P/J411, and P/J412
between the MCU Board and the Laser
Unit.
Are the connectors securely
connected?
Go to step 5 Reconnect the
connectors. Go
to step 4.
4 Cycle the power.
Go to step 5. Complete.
5 Replace the Laser Unit (page 8-31).
Replace the
MCU Board
(page 8-59).
Complete.
How to fix invalid black message after replacing a
how to fix invalid black message after replacing a toner
And I have the same problem. I buy 4 new toners and for each one i get notice from xerox 6125 invalid black, or invalid yellow. What do I need work?
My Xerox Phaser 6128MFP printer flashes a red light with a "Load paper in Tray" message, when the specific paper size and type are already same in the tray.
If the paper size is correct in the printer and the printer and it's possible to print off a test print in both the printer control screen or directly from the print driver utilities if that works then the only thing I can suggest is the item you want to print is defaulted to a different size. i.e. Check that the word processor your using is set to the size you have in the printer. Imperial size pages will look very similar on screen as does the A4. Printers don't automatically fix paper print sizes you just have to check and recheck for differences. Removing the tray only reafirms to the printer that the size might be incorrect and your going to fit the correct size.
As for the red light all printers behave differently in certain error conditions. Have you also tried to print out something you printed at a time the printer was working correctly. In other words try printing out a different file. Maybe, trying to print off a test print of one line of the alphabet, and then go from there.
Good luck,
6125N won't print in network
If you can address the printer through CentreWare then your halfway there. Is now possible to print a test print via CentreWare if that works look at your p.c, driver setup.
Good luck.
Paper jam at exit
Besides setting it for card stock both in its internal menu and the pc's menu, are you setting it for legal size paper? The timing will be thrown off if that step is missed. It will stop pulling the paper because it is looking for 8.5 x 11" paper. I would test with less expensive card stock to also make sure a shard of the decal paper did not get left in the paper path. The card stock should help dislodge any debris in the paper path.
Every printed page has a pale pink background from edge to edge
Hi again Jan,
It is possible that your drum but to be sure, get a trained Xerox Technician to check it out...
There is still a possibility that it is something else entirely, so getting a technician out would be the best bet... Sorry I couldn't give more of a definitive answer. Sometimes things need to be seen in real life to diagnose properly.
Paper jam at exit
Have you set the tray to thick cardstock in the printer?
If not try that. This will let thicker paper go through more easily.
Make sure you bot have the tray as the printjob set up as the same type of paper.
How much does the paper weigh?
Also try printing from the manual feed. You're paper path is shorter that way and easier for the printer to handle.
Does it only jam on this type of paper?
Might be a fuser easy but don't think that's the case with this one.
Printing oranges instead of browns
Sometimes the colors are off because certain (other) colored ink toner cartridge is low. See if you get the same results after you use new toner cartridges.
