Error 4
I did a power reset on my printer and it worked for a couple of days but went back to some sort of errors again, because of the refilled cartridge. I tried to reset solution from this website, How to reset canon mp145. It did worked for me.
SOURCE: Reset Waste Ink Canon MX318
Because It is full. And replace or you can clean it. Either way you must any of this two things.
Good luck.
SOURCE: canon ip2000 reset ink absorber
Waste Ink Counter Reset:
Step 1: Manual for Service mode
1. Unplug power and USB.
2. Open door and hold power button.
3. Connect power.
4. Close door, then release power button.
step 2 : Software for Permanent
1. Reconnect the printer cable.
2.Open General Tools software and select (USB PORT)
3 .Choose (SET DESTINATION 1) And it should be reset.
"After service mode Pls use software for permanent reset"
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. - If you find that the solution/answerI provided led you to, or resulted in a fix, please close the ticket with a FixYa!rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
SOURCE: canon pixma mp145
<Service mode operation procedures>
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button 4 times to enter waste counter menu.
5) Then press reset twice. LED should go green
SOURCE: reset ink counter canon mp240
I'm not sure if this is exactly what you are looking for but I came across this website and I think it may be helpful. https://www.oddparts.com/ink/cbc30_31.htm Hope it is.
SOURCE: Canon pixma mp240 ink reset
Thats funny, cause I took the cartridges out and left the lid up, unplugged it, plugged it back in with my finger on the power button and tapped the stop/reset button twice. Put the cartridges in, pressed the color start, after some moaning a test page printed. I unplugged it again, plugged it back in and I had full ink Levels!!!
