Televison & Video Logo
Posted on Nov 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My tv needs readjusted (color,focus,etc.)Is there an easy way to do so myself? i got a 1986 45'' RCA projection tv.it started of with just a blury spot across the top but after i messed with it the whole pic needs readjusted. can anyone help?
Anonymous
Level 3:
  • Master 5,138 Answers
  • Posted on Nov 10, 2009
Anonymous
Master
Level 3:
Answers
5138
Questions
5
Helped
1004564
Points
13534
First pull back Look for screen and focus block you will have 3 controls ontop for focus and 3 controls below for adjusting screen drive to each Tube R/G/B
turn color off on Menu NOW try to Adjust the red,greenand blue screen drives as close asyou can to a Black and White picture then turn Color back on in Menu also adjust Focus for each Tube Be sure to Clean Top of Tube Lenses of dust&dirt Just in case Post me your Model and Chassis Number it will be on back of TV some RCA Focus&screen drive Block maybe in front of TV if so remove front bottom panel their you will see control box.
How do i set the color for picture
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com Common Problem #1) Convergence has gone out Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
The screen is out of focus, the tv will come on but the picture is out of focus it looks like it is being stretched. Words are blury and faces are doubled.
Ur tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board is dead.The convergence board require replacing 2 STK convergnce ICS and some or all of it resistors to fix the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
3helpful
The blue is blury
This tv have a problems call convergence,it dead.The tv convergence board must have the 2 STK convergence ICS and some or all it resistors are dead.These parts must change to solved covergence problems.The shop will cost u $300-350 for parts and labors.
Rca hdtv rear projectiontv.how to adjust focus
You will want to use a funtion called either convergence or auto convergence. It realigns the 3 colors to the correct possition on the screen.
2helpful
2answers
MY RCA R61WH76 61 INCH TV IS BLURY AND LOOKS LIKE IT HAS 3 PICTUR
RCA Scenium Profiles HD61 TV IT'S AT 480i how I get at 1080i or 720i please help....thanks...
Blury ,double vision, and cant brighten up
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Its a fairly easy fix on the Hitachi sets.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
Rca 46 proj
Projection TV2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith2_bing.gif, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Blury picture
Check the connections on the CRT circuit boards. there is a red wire that slides into the white plastic socket make sure that is connected good, If that doesnt help you may need a replacement focus block, But if so they are very cheap and very easy to install, and I can post a link where you can get one if you need it.
Focus block is at max still blue
the convergance amplifier have failed there are two of them they need to be replaced. there may be some pico fuses and resistors also. convergance failure is the most common rear projection tv it makes the set appear blury.
Rca f25432
picture blury problem is due to 1 focus wire loose or disconnected due to long life of connection.this wire is in crt base. 2 focus control mistunned. 3 low voltage on crt electodes. 4 if tv is old then crt is getting weak. 5 crt base or connector loose hope this helps. good luck
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
