RCA R52WH76 Television
Problems with RCA R52WH76 Television?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Troubleshooting and Support
Solved Problems for RCA R52WH76 Television RSS Feed
Click here to get instant support from our best Experts!
View More Results for RCA R52WH76 Television
Questions and Unsolved Support Problems
Unsolved Problems for RCA R52WH76 Television RSS Feed
Answer
after tv is on for awhile screen will go black with no sound.after a few seconds tv will shut off.if... (More)
Answer
sound goes down by its self and menu comes on the screen
Answer
My RCA R52WH76 no longer has red or green color. Other than that everything seems fine, is it a bulb... (More)
Answer
i can't get any digital channels in the digital coaxil connector or in the dvi connector. How can i... (More)
Answer
R52wh774x61 - convergence problem - concave image RCA 52 rear projection how do i get to the... (More)
Answer
I did find the problem with the snowy picture, I was my six month old German Shepperd found the... (More)
Find a Manual
RCA R52WH76 Television Manuals & Guides
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
Tips & How To Guides for the RCA R52WH76 Television
Earn cash by writing Tips & How-To's.
It's easy!  (Learn more)
Mitusbishi shuts off instantly...
Most of the Mitsubishi rear projection sets made from about 2000 through 2006 have a self diagnostic check feature. It will indicate if there is a... written by SD Tech
Mitsubishi Green Blinking light of death
This information applies to Mitsubishi sets that have a Model number beginning with VS, WS, WT etc. It does not apply to the WD series of sets made... written by SD Tech
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W..,...
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W.., D56W.., D61W.. · Symptom: No Convergence, Picture is bowed and distorted,... written by johnnydiode
Samsung Color Wheel replacement!
This varies a little depending on model number of the set. Usually a bad color wheel will produce a high pitched sound or even a grinding noise; some... written by SD Tech
Sony KP51hw40 etc with Blue screen and or Shuts down
Many of these sets had problems with bad picture Tubes--they use a red, green and blue crt. Most commonly the blue gives troubles--The tubes are now... written by SD Tech
PANASONIC CONVERGENCE DO IT YOURSELF REPAIR
So many people ask me about this here are my Instructions if convergence will not adjust and or is skewed: PANASONIC CONVERGENCE... written by SD Tech
Solution for Video looking whiteish, dull, or too red
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D... written by Ecollier2012
Why my TV does not start up and remains in standby?
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also ensure that the fault is not coming from a faulty receiver... written by ginko
I need help with
near zipcode:
Please enter your zipcode
Search
Top Repair Providers for RCA R52WH76 Television
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Ratings for the
Find a Warranty
RCA Contact Information
Main support number580-634-0151
Describe your problem:
Top Projection... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
