My wife complains that the washer sometimes takes all day to finish a load and that it seems to be in the spin cycle for extended periods.
Thank you for your post, Tom Lau!
I see that you are having a difficult time with your Frigidaire washer, FAFS4474LW, taking long a time to complete a cycle and not rinsing the clothes out enough. This could be a possible problem with your sensor or control panel on your washer. You may want to perform a reset on your washer to help clear out any miscommunication within the washer. In order to perform a reset you would need to flip the household circuit breaker off for roughly ten minutes. If you continue to have issues with your washer after the reset I would recommend seeking assistance from a professional. This will help you to avoid any unnecessary part purchases. Best of luck! -Matt
Thanks, after doing some research here, I found a sock that made it's way into the drain pump filter!
Machine stops when it comes to spin cycle. I get code F21, and I search drain holes and water valves, everything seems to be okay. When I try to drain and set, the machine sets on start cycle again.
