One day it here recently, it would not turn on. I never had any issues from the set and one day nothing. It does even sound like it wants to turn on. So, I tried the oldest electronic trick. Unplug it for a while and try it again, still nothing.
-   We have had the same problem with our tv. We replaced the fuse with a 6.3 Amp 250 Volt fuse just like other users have suggested. Now we have ppower on the tv, but the picture is dark. Is this caused by the 250 volts? Do I need a 125 volt for it to work properly? Or are we simply out of a tv? There are no service repair places where I live and we cannot afford a new tv. Any help is greatly appreciated. Thank you and God Bless!!!-   aparrack05
Mar 05, 2009
-   I'm convinced that I need to replace the fuse on my TV so I removed all the screws and the bottom pops out fine but the top does not want to pop out. Do I need to have the TV at a certain angle to get the back to come off? Any advice would be greatly appreciated.
-   I'm having the same issue I think... My TV won't power on at all and I can't seem to find the fuse. I have been in both sides of the TV and can not locate it. any hints as to where it might be? This is my first time in the back of a TV, computers are more my thing but I really want to get it fixed with out spending 150 bucks or just buying a new tv.
Thanks-   lairdn
Aug 26, 2008
-   Hi:
The power on my 10-12 year old Panasonic 32" color TV doesn't turn on with the Remote or otherwise... any suggestions to repair it cheap. Could it be power supply / transformer problem... can I fix it myself? I hate carrying it to a repair shop (it's heavy) just to find out that it'll cost a bundle which may not be worth it.
SKG-   skg4y
Apr 06, 2008
-   two years old nothing happens when trying to turn on-   Guest
This sight rocks! And so do the people that posted information! Went to Radio Shack and got the 6.3amp 250 volt fuse. Fuse was easy to get to once I removed all of the screws and easily slid off the back. $2.99 fix (foe the fuses)
Was this helpful?
Yes
No
4 people thought this was helpful
Solution #2
posted on Mar 26, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
sorry I meant 6.3 amps/125 v it is not 63 amp fuse like others have said..anyhow where can I buy a 6.3 amp glass fuse
I live in Whitby, Ontario Canada
Solution #3
posted on Feb 13, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Thank you for this helpful tip! I found the fuse and that was the exact problem! Thank you again for saving me $80 service visit plus labor plus parts. Just to clarify it was a 63 amp fuse for Panasonic model number CT-36SL13G.
I too had the same problem with suddenly no power to my Ct32sl214.
I read the solutions and wanted to commend Terryfic, whose solution worked.
" Check AC fuse ... if bad 6.3 amp...replace with slo-blo..T-type 6.3 amp.....original is fast-blo"
The TV weighs 160 lbs, but car is not large enough to bring TV to repair shop which would usually run $39.00 just to drop it off. My tv repair shop wanted to charge $125 bucks just to come out for the housecall.
I located the fuse right near where the power chord connects to the circuit board and removed it with ease. You can see the fuse when your unscrew and remove the small chord bracket on the rear of the set and peer down with a flashlight, but you need take the back off the TV to access the fuse.
I then went to the same repair shop who didn't have the replacement fuse, but referred me the radio shack up the road who did.
I only had to shell out $2.99 for four replacement fuses, saving at least $120.00 for a house call.
Thank You
Ken
kschae4@aol.com
Thank you very much T. I got mine fixed with a 64 cent fuse :o)
Comments:
Jan 30, 2008
- yeah you can do this yourself. take the back of the tv off and if I remember correctly its on the right corner of the board, just make sure the tv is unplugged and don't touch anything else. Its a tube fuse very easy to find
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #7
posted on Oct 30, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I had the exact same problem with this TV. So I googled the model #CT-36SL13G to see if the TV was worth anything. I was hoping I could get someone to get it out of my house for free becase it is a big heavy elephant. Instead I found this page, went to went to Radio Shack, got the fuse, replaced it, and it works perfect!
I do want to add a couple of comments. The fuse is a little tricky to find if you do not remove the panel completely. Be aware that there are the screws that go around the edge of the panel. BUT, then there are 2 or 3 screws that are around the RCA jacks. You need to remove these screws so that you can remove the cover without pulling the circuit board out. Once you do that, the fuse is right there near the power cord. Also a WARNING: I am not a TV expert but I believe they still have capacitors wich means you can get zapped pretty bad even with the TV unplugged. SO, try not to touch anything other than the fuse.
Solution: My Panasonic 32inch flatscreen TV had the same problem described by others. I hit the on button, heard a "pop" and it simply would not work.
I went to Radio shack and they have a 6.3A 250v slow
blow fuse. I did not even know what a fuse looked like . . but once I got the part, it was simple. Took off the 8 screws on the back of the set, and popped out the old fuse. my original fuse was a 6.3 amo , 125 volt version, but so long as your new fuse is rated equal to or above the voltage amount, you are fine.
Unbelievable, I have never repaired a TV in my life and this saved me $500 since I would have replaced the TV with something new.
This was very helpful. We also have the Panasonic Model CT-32SL14J and it just quit on us. No power, no picture, no nothing. I looked up this site and my husband and I did as suggested. He removed 9 screws on the back and we removed the back of the TV and (facing the back of the TV, on the lower right hand side), there was the fuse. Went to Radio Shack and bought one package of 6.3 amp 250 volt slow blo fuse (there were 4 fuses in the package) and the package was $3.00.
We replaced the new fuse and lo and behold, problem was fixed.
I had called a television repair place a couple of days earlier and they had quoted me $145 just to come out to look at the tv.
same problem as everyone else only the fuse did not work, now it clicks and acts like it's going to come on but don't
Was this helpful?
Yes
No
Solution #13
Guest
Rank: Apprentice
Rating: 0%, 0 votes
where can you buy a 63 amp fuse ? I pulled my out it and it is bad-I called the source and they said they do not carry it-I live in whitby, ontario, canada
any help would be great.
Solution #14
Guest
Rank: Apprentice
Rating: 0%, 0 votes
where can you buy a 63 amp fuse? my is bad and pulled it out I called the source but they said they do not carry it-I live in Whitby, Ontario Canada
our TV has suddenly developed a problem - it turns on but immediately turns off again - cannot get...
(More)
our TV has suddenly developed a problem - it turns on but immediately turns off again - cannot get any channels or play dvds through it
I have the exact same issue on my Panasonic CT-32SL14J. The local repairman said it would be about $100 to fix. Where is the fuse located? Can I do it myself?
