Question about Panasonic TX-28CK1 28" TV
Panasonic CT-35HL43 36" TV has NO power
I have no power, no front power light, nothing. The set worked fine on Friday afternoon and when returning home Sunday...zip. Nothing I can do resolves the issue. I tested the power supply and all is go. Any ideas? Television won't power on. Keeps switching off before picture comes on.
Posted by taximanian on
Larry
  • Panasonic Master
  • 2,800 Answers
Something is shutting down the power supply, most likely from over current
Posted on Feb 13, 2018
2 Related Answers
Anonymous
SOURCE: panasonic CT-35HL43 36" TV has NO power
Same problem. I have the CT-32HXC14. I agree, you need a crane to move this thing!
Posted on Apr 24, 2008
Anonymous
  • 3 Answers
I bought the fuse at Radio Shack for 5 dollars and replaced the fuse myself. The set now works fine. It cost me more in the gas to go and get the fuse than the entire repair cost. There are screws on the back of the tv that you will need to remove. Once you remove the screws you will need to PARTIALLY remove the back cover. It was not necessary to remove the entire back cover. If you look into the back where the power enters the television you will see the fuse. It is small, so look carefully. MAKE SURE THAT YOUR TELEVISION IS UNPLUGGED! I repeat. MAKE SURE THAT YOUR TELEVISION IS UNPLUGGED! Pull the old fuse and replace it with the new. Cost me about $10 total.
Posted on Jul 29, 2008
My Panasonic CT-27SC14 tv won't turn on. worked fine last night. The cable box does but nothing happens with the tv..whether I use the remote or the power button. Unplugged it from the power source and...
hi,disconated from AC main. if you know bit of repairing tv and soldering? this what to look for main power board. 1 x dry joints 2 x leaky capacitors just remember when changing cap's make sure to use the 105' and same value.
Feb 04, 2010 | Panasonic CT-27SC14 27" TV
32'' Panasonic television. Power switch does not turn the set on.
1 It appears that connecting cable is faulty. Normally when you connect and push the power switch the standby light should lit. Try the cable on another appliance and see its function. Also switch on the TV and try to switch it on with your remote control.
Nov 19, 2009 | Televison & Video
My Panasonic HDTV will not turn on
Mine did the same thing. Did you find out what to do?
Oct 11, 2009 | Panasonic CT-26WX15 26" TV
Tv won't turn on at all
no remote but tv was working with front power key? unplug from ac outlet and plug back and listen for any type of indication (noise or chirp) that something energizes inside if theres nothing then suspect a power supply problem, main fuse blown, shorted low volt rectifiers other components could be at fault.
Aug 05, 2009 | Panasonic CT-32SL13 32" TV
Tv wont turn on
take your tv to technician who can check your power supply, if your power is coming on and off, than a problem is not as big. firstly let him check a ht of a supply constantly, your supply is cutting.
Nov 03, 2008 | Panasonic CT-32SC13 32" TV
No Power on Panasonic 36HX42
The TV cannot sustain power - well the good news is, it is on the POWER SUPPLY section inside the TV
Jun 18, 2008 | Panasonic CT-36HL43 36" TV
Tv wont turn on
stephster, check to see if you have a reset button on the back of tv good luck-hope this works for you
Nov 05, 2007 | Panasonic CT-36HL43 36" TV
Panasonic TX14S2T
What are the symptoms? Is the set dead? Please clarify
model number from back of set...The red power light coming on means the AC fuse is OK, but the B+ fuse may be bad. If that
is true,check the horiz o/p xistor and get back to me....T.
Oct 20, 2007 | Panasonic CT-27G14 27" TV
it could be the ac fuse gma 6.3 amp my ct-36hl43 did the same thing cost a dollar for the part 99 dollars laborer [email protected]
Sep 30, 2007 | Panasonic CT-36HL43 36" TV
Panasonic TX-28CK1 28" TV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
