HP LaserJet 1160 Printer
Problem for HP LaserJet 1160 Printer
Problem for HP LaserJet 1160 Printer\r\nFatal
By ramadoss_201 on Oct 24, 2009
Problem for HP LaserJet 1160 Printer Fatal error light pattern pls help with the hp laserjet 1160
Solution #1
posted on Oct 24, 2009
Not Rated)
sunnylab85
Rank: Wiz  HP Expert
Rating: 73%, 116 votes
Check if paper is in the printer because that may cause the print to show that light or maybe the hardware part are not properly fit to the printer
Was this helpful?
Yes
No
Popular Solutions for HP LaserJet 1160 Printer
Questions and Unsolved Problems for HP LaserJet 1160 Printer
Do you recommend HP LaserJet 1160 Printer?
Answer
Answer
It used to work fine but now it often gets an error in the print cache after printing ten times or... (More)
Answer
I am able to print excel or word documents, but when I try to print from a webpage all I get is... (More)
Answer
Ever since our switch with otherating systems, this printer will print fine put when you change the... (More)
Answer
the problem is the Attention, Ready, and GO LEDs are on solid. i already try to solve this problem... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP LaserJet 1160 Printer:
Top Printer Experts
Rank: Guru Guru
Solutions: 758
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
