Hello. First thing you want to do is listen to see if you can hear the compressor running. It is the round tank in the back. this holds and pumps all the freon through your unit. If it is not humming, then it will not cool. This is probably the most expensive part. Around $250-$400
If compressor is running, then you will want to look in the evaporator tray attached to top of compressor. It should have some water in it. If not, check that the drain tube above it is not blocked. If so, unclog it.
If all this is working fine, then your problem is in the temperature control unit. Either temp control itself, or the temperature sensor which is located inside the and above freezer panel.
Last possible cause would be the control board which also runs to
the compressor and can automatically shut the compressor off it it
reaches a certain temperature.
The best bet is to get manual and any parts at www.repairclinic.com
Hi
Thanks for using FixYa. In a
self-defrosting freezer, poor cooling often results from a heavy frost
build-up on the evaporator coils. To access these coils you need to remove
panel inside the freezer. If there is any frost or ice build-up on the inside
walls, ceiling, or floor it’s sign of frost build-up and it means a
problem with the self-defrosting system.
Freezers should self-defrost three to four times in 24 hours. In case a
component in the self-defrosting system fails, the freezer continues
to try to cool, instead. Eventually, so much frost builds up on the evaporator
coils that the circulating fan can't draw air over the coils. There is some
cooling as the coils are frozen. But with no air flow over the coils, the
cooling is quite limited and the freezer isn't cold as normally it
should be.
To check the de frosting system problem, you need to remove all of the
perishable food from the freezer, turn the thermostat to off, leave
the door open for 24 to 48 hours to "manually" defrost the freezer.
After the frost and ice build-up is completely melted away, turn the thermostat back
to a normal setting. If it is cooling properly, it indicates a problem with one
of these components in the self-defrosting system:
Please do accept the solution if the issue is resolved or else revert for
further assistance.
Thanks
Rylee
my kenmore elite 7350 bottom freezer stopped cooling, it sounds like the compressor is running , do i have to open the back of the refrig to get to this evaporator tray?
