PSP Screen wont Come on, But sound and backlight does, WTF HELP!!!
Ok, so the Sinopsis is this: We were out for dinner when my PSP Fell out of my pocket, maybe 2 feet, and WHAM! Everyone looked at me, so I picked it up, put it back together (The Battery, Memery Stick, and Battery Cover all came out, so did the Game) And turned it on.
Blank Screen.
The Back light turns on, So does the sound. At first I thought something was broken inside, so I unscrewed it and peeked inside. Nothing. And I didnt HEAR Anything when it was together Either, SO I think its NOT The inside.
The next thing I realized is that the LCD Screen (The thing that wont turn on) IS NOT CRACKED Or Scratched or anything.
Is there A Button or setting that Turns the Screen off? My father has a PSP So I could use his to navigate mine to certain settings, and all the buttons work too.
This is a NEW StarWars WHITE Darth Vader Eddition PSP, and a week later its broken.
Christmas is in 3 Days, and I just found Out I am getting some games for it eventhough I didnt ask for any (I wonder why...) and I'll feel really guilty if I have to tell my Dad, because this happened almost a Month ago.
I didnt do anything about it cus I thought Maybe it had overheated or something, so someone, PLEASE Help me, I am seriously BEGGING You to help, or ill have ot go to my dad and tell him its broken
i have the same poroblem and wen i switch it on it has a blank screen and nothing on display plz could sme 1 help[ mei have the same poroblem and wen i switch it on it has a blank screen and nothing on display plz could sme 1 help[ me
You can't post conmments that contain an email address.
Re: PSP Screen wont Come on, But sound and backlight...
Hmmm ummm i think its because the back of the LCD screen is broke. My psp once Fell 3 feet...it didnt break just do the warranty thing like the other guy said
If you go it a month ago it is still under warranty. also try to press and hold the bottom that changes the brigthness for more than 5 second. It may be that
sounds like the display board went. here is a cheap and fast repair guy. he has repaired my PSP several times and does excellent work.
http://www.psprepairservice.com/
ok well the laser is bad or something else in your psp but if u would like to get games for free and etc all u have to do is put custom firmware and ill do everything and anything to help u from there so email me at [email protected]
the downloads dont matter.u change the battery and if it doesnt work take it to a shop.if u have spill water on it open the psp cover and everything and for 2 days put it in the hot sun
I recommend seeing an expert. I heard that to replace the internal screen only costs about 20 dollars if you do it yourself. You should look into buying a new screen(internal) but about the leaking LED's you should really try to see an expert or get some support from Sony.
You might have the broken LCD.. If you not sure, try to boot under recovery menu - (if you have custom firmware installed). if the problem come from corrupted firmware you should see the menu of recovery.. then goto menu "Advance" > "Format flash1 and reset setting". otherwise you may consider sending it back to Sony for repair.You can call SONY support at 1-800-345-7669.
hopefully this help.! Pls post back should you need additional information, and also Show your Appreciation, to help other USER. http://e-arena.blogspot.com.
it's easy..to solve it... i have same problem tooo...., i disamble my psp..try to replace lcd,,but same problem...., i figured it out... with full day thinking..., n rechecked all mainboard..., finally found the problem...., just email me...for those who want to solve this problem....
[email protected], even newbie.. can do it..., just do it with carefully...no force needed..
if the psp screen is anything like a laptop it will have a backlight that lights up the screen what can happen is you can break the light and while you will still see things on the screen when you look closely but it wont be illuminated. i had a friend that dropped his laptop and smashed the backlight he sent it away and got it fixed
i suggest you send it to sony to get it fixed
The backlight is probably gone. Just had same problem on my sons one. I purchased a replacement off ebay seems a simple enough job to do if you are sort of tech minded.
