You probably need to replace one of the brushes on the motor. ------- Check your motor as well. Sometimes the motor or motor switch won't allow it to go into high spin. ------------ it can also be the door switch problem.or a faulty door lock. please click the link directly to check the door switch adjustments http://www.applianceaid.com/ads/doorsw417.jpg --------------- most probably its door switch or door lock or the motor.one out of this three is faulty so the machine is not running spin cycle. --------- check out one by one.you can get the required parts from www.repairclinic.com or from at ----- www.partselect.com --------- this will help.please do rate the solution.thank you for usingfixya.keep updated.thanks.
