I have a laptop with a verizon wireless card. i also have a wireless router. how do i get the internet on my ps3.when i test it says" dns error" 80710102
This can be accomplished by using a network cable called a crossover cable (cat5 type). This cable is used to connect two computers together. With everything off just to be safe connect your computer to the PS 3 using the LAN ports on each. Start the computer and get online with the um150 then turn on the PS 3. In Windowsxp go to start, programs,accessories,communications,
network setup wizard.Run the wizard. Click next twice and in the third window that pops up you should see Pantech usb modem which is the um150 and local area connection 1 for your computer.
Mine is realtek Ethernet NIC yours may be different but look to see if you have an ethernet connection with NIC in the description. If the box says that a cable or cables are disconnected click the ignore disconnected radial button and click next. In this window choose the top radial button that says
this computer connects directly to the internet. Continue through
the wizard, you won't need printer sharing, and it should have automatically checked the correct connections to be bridged. What this does is bridge the um150 with your NIC through to the PS 3 by the cable. Click next and name your computer and network, you can leave the defaults if you want. Click next to set up the network. At the last window you don't want to set up any other computers so choose the radial button that says "just finish the wizard" should be the last one. The downside to this is that the um150 uses a different IP address every time you connect to the internet so you will have to go through this procedure each time you connect. Now go to the PS 3 and network settings and choose check for wired connection and it should connect.
Good news. cradlepoint Technology,www.cradlepoint.com, has available the PHS300 Personal hotspot router. Just plug the UM150 into the router and it creates a WiFi hotspot with a range of about 60 feet. I use it for my home network as the UM150 is the only broadband available to me. This works great for the Wii and PS3. It took about 20 minutes to set up including a small update for the router which may not be necessary anymore. The only downside to this is the router is about $150.
Enable internet connection sharing from your laptop after disabling DHCP on your router. Once you do that, your PS3 will grab an address from your laptop, rather than the router. Try connecting then....
I dont know why but this didnt get it to work and nothing else will
Your wireless router probably has a wep or wpa passcode that you will need to enter into your PS3.
hi. i have a lap top..wireless broadband.. usb modem.. from verizon..call the UM150{?} i wanted to play my ps3 online..with it.. and i tried to connect the modem onto my laptop..and then a usb cord from my laptop to my ps3..but it seems to not be working.. plz help.. or is there just no other way??
i have a verizon wireless card on my laptop and i cant connect it to my ps3 how do i do that
what about on vista?
Can this same process be used to connect the um150 using windows vista?
will this work with the 720usb card from verizon?
i got the same problem bro, we need some help out here
hello i just got a new playstation 3 160 gb. I have a laptop with the new verizon high speed broadband card. ive tryed multiple time to set up a wireless network but i just do not understand. my main problem is that i dont have a clue how to get my ps3 connected to the internet. if anyone could help me please give me a feedback at
I have the same problem but when i tried what is said below, it said i have a "DNS error (80710102)" If anyone knows how to deal with this problem also, could you please post
