I have just brought my daughter an AKAI CT-K147 tv and trying to tune in here DVD player but for some reason I can not find the AV button and we have no remote for it, can anyone please help?
Hello
Your Emerson Sponge Bob's model will be SB350. It is a TV/DVD combo, with two AV inputs too. You ahve to see only DVD player with it as you says. You can change its mode to eiter TV/AV or DVD/TV by its remote control buttons. Press the DVD/TV mode button on the remote control to chage the modes to TV or DVD. On DVD mode, you can play DVDs with it. I thinks that you have its user manual with you now. Go to its pate [23] where there is illustrations for which button on the remote control handset should be pressed to select this. If you haven't its user manual with you, send your email address to me by FixYa comment box. I'll send a copy you the user manual to you by return mail. OK.
You don't need to tune a DVD player to the TV but you will need to change the input mode on the TV to either RGB or AV (depending on which input you connect it to)
Sorry can't help you with the manual
Check the scart lead by substitution, try another source of input, (game machine or dvd player,) it,s not uncommon to find bad solder joints on the print, where the scart socket is soldered to the mother board of the telly. there is no tuning as such for scart sockets, but you can get them in the wrong mode? S-video etc? but you should, in that case, get some sort of picture. Good luck! Nick
Hi
If your t.v.has built-in blue screen when there is no signal, then the DVD may have been accidentally switched to progressive scan mode, or defaults to that setting if new. If your T.V. is not capable of displaying in progressive scan mode, you will just get a blue screen. If you have an older tv, without blue screen, then connect it to that, and if you get a black and white split screen when you turn on the DVD, then progressive scan is the problem. Check the manual for the DVD player for the procedure to get out of that mode, and it should then work. If you still have no video, and you are using the yellow composite video jack on the back of your DVD player, then it must be brought in for service.
Good Luck!
I am having the same issue with mine. I even set everythign back to factory defaults and it still wil not work. Isn't there any tech support palced to find help? See post by Scriptster. Thanks
