Televison & Video Logo
Posted on Mar 23, 2010
Cant tune tv in to use xbox 360
I plug scart leads into tv and can only hear sound on av channels is there a way of tuning av channels?
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Mar 23, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
580
Points
Check the scart lead by substitution, try another source of input, (game machine or dvd player,) it,s not uncommon to find bad solder joints on the print, where the scart socket is soldered to the mother board of the telly. there is no tuning as such for scart sockets, but you can get them in the wrong mode? S-video etc? but you should, in that case, get some sort of picture. Good luck! Nick
How do I tune a tv to sky channel
Turn on sky box, select a menu so you have a steady output.
Easy way is a scart lead (no tuning required) choose "av1" or whatever your plugged in to.
If just using ariel lead, pick a channel on tv for example no 6 and tune that to frequency 68.
If your tv does'nt use these numbers then scan until it comes through
I cant tune my channel in for my xbox 360
you need to plug into a scart socket and select the av channel to suite.
3helpful
Just got logik ldvr 1608 dvd but it cant find any
You need an aerial to tune the freeview.
However, to record from satelite you can connect a scart lead from the satelite vcr out to the dvd in and it will record vie the av "channel" on the dvd.
Depending on your location, regarding signal strength, you can purchase an indoor, boosted aerial to tune the freeview.
Also, if the scart connection on the dvd is a 2 way connection( allowing a signal to the tv as well as from the tv) you can connect the tv to the satelite and the dvd to the satelite only and the dvd will play through the satelite even when the satelite is off.
When I play Halo 3 it turns green. and other games get blurry in background, I just bought Fable 2 and I cant play that because it is too blurry, its not a scratched disc, and I rmoved dust in my 360
you may have a faulty AV lead, from xbox to TV.
or the graphics chip is failing, if you have a composite lead ( red-white-yellow-green-blue ) check that the switch is set to hdmi correctly. this is on the side of the oval connector from xbox outlet to tv lead.
try tuning into a different tv channel, check that the lead isn,t broken internally.
If this does not work, assume that the GPU Or graphics chip has come loose, and obtain A RROD repair kit.
Mike @ Compurepair.
XBOX 360 NO PICTURE
if using hd tv then use the cable with the blue lead, if not using hd tv then use the red, white and yellow leads. If using the scart connection to put the leads into make sure that you have it set to the correct av or ext channel
1helpful
TV, freeview, DVD and video set up.
Hi.
Modern day freeview boxes rarely have A modulator in them so you can not tune it to a channel on your tv it must be connected using scart lead.
Most freeview boxes have 2 scart sockets one for VCR & one for TV plug your scart leads in to the scart sockets of freeview they will be labled TV & VCR.
The scart labled TV goes to scart socket on the TV labled AV1 or 1
The scart labled VCR goes to scart socket on VCR labled AV or IN
Now the aerial leads From wall socket to ANT in on freeview.
Then from RF out on freeview to ANT in on VCR.
Then RF out on VCR to ANT in on TV doing this will enable you to put TV on 9 to watch tapes.
The final scart will be from DVD to TV socket marked AV2
You will need to put TV on AV channel to view freeview.
To record freeview you must put VCR to EITHER line.av,aux. it will be one of those different manufacturers call them by varying names.
I have done this banking on your tv having 2 scart sockets if it only has 1 let me know & I will tell you how to wire it differently.
Please state make & model of TV set & VCR & what connections are available EG scart, Phono, Svhs etc.
http://dysonmanuals.llc.nu/
Chris..
1helpful
Can't re patch tv with set top box to watch tv
Hi.
Ok here goes.
1) Take airial lead from the wall socket in to antenna in on freeview box.
2) connect short usually black airial type lead in to antenna out socket on freeview. plug the other end of this lead in to aerial in on vcr.
3) connect the other end of this aerial type lead to airial plug on the back of tv.
4) now if you have 2 or more scart sockets on the back of tv set plug in the scarts in this order.
Freeview box scart with tv on it connect to scart 1 on tv set.
Freeview box vcr scart connect to vcr in scart socket on vcr.
Vcr scart marked tv plug scart from here to scart 2 on tv
If you have 3 scart sockets on tv you can connect dvd using scart to scart socket 3 on tv.
If Tv has only 1 scart the aerial leads will stay the same as I have stated,
Freeview must go to scart socket on tv set.
leave second scart from freeview to vcr plugged in so you can record freeview by putting vcr to line 1 or AV 1.
you will need to put tv on channel (0) & tune this channel to the video play a tape that you recognise then go to tv tuning & tune tv untill you see video playing then store this on channel (0).
DO NOT USE AUTO TUNING IT WILL PUT CHANNELS IN THE WRONG ORDER JUST USE MANUAL TUNING.
Now to view Dvd you will either need to purchase A scart switch box. Or have keep unpluging freeview scart from tv so you can plug in dvd .
If your tv has red yellow white phono sockets you can plug dvd in to these, you may need to purchase phono leads.
Hope this helps.
Chris..
Tune playstation 3 to toshiba television
first try to manuall select your av channell from your tv's remote control,if this won't work try another scart cable or port on your tv set
2answers
Tuning a samsung tv to a phillips dvd, a goodmans video and an akura freeview box
It sounds like you are trying to tune in the dvd and video to a free channel on your tv, I would suggest using the scart connection if your tv has one. Scart leads only fit in the one way so you cant go wrong. Scart leads are available everywhere including tesco.
Once the scart leadt isconnection between the dvd and the tv then use the AV1 button on your remote controll and you will get sound and picture in better quality than manual tuning.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
