SOURCE: My RCA450 universal remote control does not have a code search button
the rca systemlink 4 remote is very good.it has code search and menue
try also the menue button on the tv itself
SOURCE: wii remote not working
it sounds like it could be faulty but I got this info from nintendo's website and at the bottom there is a customer service phone number that will help with any other problems relating to remotes for the wii
Still having problems? If the basic guidelines above did not solve your problem, the more specific information below may help.
I know this says if your console does not recognise your remote, but they should be able to help you with your problem too
Getting the Wii console to recognize (or "sync" with) a Wii Remote, especially one that did not come in the box with your Wii console, may require doing a few additional steps before it can be synced. Additionally, a Wii Remote that was working, but is no longer being recognized (or has "lost its sync") may need to be re-synced. Please use the troubleshooting steps listed below, which our experience has shown can solve many Wii Remote issues.
Try these steps!
If you are still unable to get the Wii console to recognize your Wii Remote(s) after carefully following the steps above, please call 1-800-255-3700 for further assistance.
SOURCE: Keyless remote Problem for Yukon Denali 2005
Have your dealership test the remotes for you, they will also use a "Tech-2" to re-program it and should not charge you to do so. "I know mine does not" The "puddle" lamps come on when you un-lock the doors with the remote."If they are enabled in the options on your dash information center or "DIC". "See owners manual for info on that". As far as the DRL's make sure your bulbs are good because they are known to blow out. But the remote should not have anything to do with those.Hope that helps a little?
SOURCE: Programming remote, unit will not flash.
The easiest way to program is to hold the button on the remote while you press and immediately release the smart/learn button. If it worked before there is no reason for it not to work now unless it totally failed.
SOURCE: bn59 00463 volume works nothing else cant turn on
Step 1: Remove the batteries
Step 2: Press the power button (red button) on the remote control 5 times.
Step 3: Replace the batteries and your remote should work fine.
