SOURCE: Tank full light stays lit.
Under the water bottle is a drain hole,when the bottle overflows water runs down this hole through a pipe to a reservoir behind the condensor unit, there is a float in this reservoir that rises and clicks a switch that activates the full tank light and stops the machine working,
removing the stopper at the rear and emptying the reservior should do the trick,If the float does not go back down due to dirt in the machine the left hand side panel can be removed by taking off the top then the retaining screws,one inside at the top the rest in the back panel,remove the one screw holding the float switch unit and clean the black float.(Make sure it's not plugged in)
SOURCE: On rinse cycle, water is pouring out of the
Check the hose from the detergent tray to the drum to make sure that it is free from debris.
First take the top off by removing 2 screw in the back(Top right and Top left). Slide the top off and underneath the tray, feel around the tube to see if there is any blockages. You may have to pull the hose out.
SOURCE: Elextrolux French Door Refrig EI28BS5TISO
We are having the same problem. Water works but no ice!! Service man replaced the computer board but it has failed again.
SOURCE: My GE #SL251FRF refrigerator ice dispenser not
I have the same problem. Did you ever figure it out?
SOURCE: spin light is flashing 1min left in cycle door
Take the bottom panel off. The tech sheet is right there. While at it clean out the pump filter.
Interesting home videos
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
