SOURCE: I can't load photos onto my digital photo frame
The A701 is a bit cranky. I've found that it prefers USB flash sticks of upto 2GB. It likes the flash stick formatting before use. And it prefers jpg files added to the root directory of the flash stick - so no images in folders. Finally but probably least important, it's not much point uploading 2MB jpgs as the screen is pretty much 72DPI smaller size JPGS lead to a faster loading. ( try around 900x 600 dpi )
SOURCE: Problem loading Quickbooks
Hi Mike,
First try reboot your machine, in case an update required a restart.
If that doesn't fix the problem, the next step would be to go to the task manager (Ctrl/Alt/Del) and go to the processes tab. Scroll down to QBW32.exe, highlight it and then click End Process (at the bottom right), then click file and exit.
Restart quickbooks from the icon by right clicking and clicking open. Do this only ONCE, hit it more than once will make Quickbooks attempt to start multiple times. Give the program time to launch.
If this doesn't work find the reboot.bat file (do a search for this if you can't find it in the quickbooks folder) - double click on it to run it. Once that is complete try again to restart Quickbooks.
If you are still having trouble you can try a a repair of quickbooks (2006 and higher). Go to the Control Panels, add remove programs, scroll down to quickbooks and click on Change remove button, choose the repair option.
If this doesn't work, you will need to do a clean install - (be sure to copy your quickbooks files to a remote disk or into another file (my documents would be a good place to put them if you have to put them on your hard drive) - If you get to that point ask about doing a clean install and I will be happy to walk you through it -
SOURCE: GE WHDVH626fWW Door Locked, but not
Mine was doing the same thing. Upon closer investigation the drum seal was torn near the door locking mechanism, and when water got on the locking mechanism it shorted it out until it dryed. Then it would work again. You can check this by pulling the seal back on the locking side of the door to see if its torn.
