SOURCE: polaroid izone 300 battery
From what you say I imagine this is built into the case with no opening to allow removal. So that it is recharged in situ. It that right. If so Polaroid is the only place to go- unless you can open up the camera to see what the battery is like. I imagine that in fact it can only be a standard type of battery but perhaps modified to fit he Polaroid housing. Have you actually checked Polaroid Tech Support Team re this
SOURCE: when i try to charge my battery the red light keeps flashing
Could be battery or charger. 1. Buy new battery. Still in trouble? 2. Get new charger Its good to have two batteries
SOURCE: HOW TO CHANGE OR CHARGE THE BACKUP BATTERY?
y hp6365 keeps telling me that i my backup battery is low..i keep charging my phone but the only the main battery is charging..how do i charge or change the backup battery?
sounds like the battery is bad and not taking charge.replace battery attemp again if not then check for fuel, spark and compression.then c wat happens or wats not working any motor no matter how small or big has to hv those three things to run. hope this helps.
