20 Most Recent Polaroid i835 Digital Camera Questions & Answers
This link should help you retrieve your deleted pictures:
http://www.cardrecovery.com/how_to_recover_deleted_digital_pictures.asp
Polaroid i835... | Answered on Feb 20, 2014
It should be in your menu as a Reset or Default Options.
Check your manual for the location.
Polaroid i835... | Answered on Nov 04, 2013
I'm sure you may have heard that when you delete a file from a computer, it is never "truly deleted." That statement, however, is only partly true. The files do not get deleted after, only the space that they occupy on the disk get prepared to be written over. When you reformatted the memory card in your camera, it did exactly that, and only prepared your pictures to be written over.
SO, the first thing you have to do after format is to not save any more pictures onto that memory card or you risk writing over the pictures that you are trying to recover!
Got that far? Now you need to choose the appropriate photo recovery software. There are a TON of different programs but some are better than others. I actually recommend a program called 001 Picture Recovery because they have an option that is designed for recovering photos from FORMATTED memory cards, not only deleted or corrupted photos. You can download this software here: http://www.001-software.com/picture-recovery/
Lastly, if the program does not recognize your SD Card as a drive when you are plugging the camera directly into the computer, you may need to directly plug your card into a card reader. Make sure that the card reader has the capabilities to handle your memory card though. Many older card readers can only handle cards up to 2GB, so if your card is bigger than that, you need a newer card reader.
I hope that helps, and that you get your pictures back like I did!
Polaroid i835... | Answered on Oct 22, 2013
see this causes and fix it. God bless you
AF assistant Beam is set to OFF , activate it.
2) Subject is out of focal range
3) the subject is hard to focus on, use the focus lock to shoot.
God bless you
Polaroid i835... | Answered on Oct 20, 2012
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Polaroid i835... | Answered on Aug 11, 2012
Hi Miguel...
Go to the following webpage and download your free user manual for your Polaroid i835 camera
Bud
http://www.ps2netdrivers.net/review/polaroid.i835/#manual
Polaroid i835... | Answered on Oct 24, 2011
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out (note 2GB or less standard SD cards are very inexpensive these days, and are available on Amazon if your local store no longer carries them). There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Polaroid i835... | Answered on Sep 18, 2011
Here is a tip that I wrote about SDCards and how to unlock and lock SDCards. If youare getting a memory card locked message then check this out.
How to UnlockSD Card heatman101
Polaroid i835... | Answered on Sep 14, 2011
Here is a tip that I wrote about how to find the manuals, drivers, downloads andsupport for Digital Cameras.
DigitalCamera Manuals, Drivers, Downloads, and Support
heatman101
Polaroid i835... | Answered on Sep 07, 2011
Here is a tip that I wrote about how you might be able to recover things from a memory card or camera
How toRecover Deleted, Corrupt, or Unreadable Files from Memory Card
heatman101
Polaroid i835... | Answered on Aug 24, 2011
Try to open it in the view pictures mode...and if it does the same you should have it checked cause it has a power short or some physical issues..If it is working on the view pictures mode..it means the batteries you use are too weak ...and you should get a much quality brand..or ..consider to buy some rechargeable accumulators.-they have a better impedance and usually last more
Polaroid i835... | Answered on Jul 25, 2011
Checkout this tip about digital camera error messages
Lens Errorfix for Digital Camera
heatman101
Polaroid i835... | Answered on Jul 05, 2011
http://www.manualnguide.com/manual-get/17769/
Polaroid i835... | Answered on May 03, 2011
heatman101
Polaroid i835... | Answered on Apr 28, 2011
Polaroid i835 Digital Camera Logo
85 questions posted
Top Polaroid Cameras Experts
Damen Wong
Damen Wong
Steven Wander
Steven Wander
Marvin
Marvin
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
View Most Popular
I Polaroid
  • I Polaroid
Most Popular Question
any way retrieve deleted images from
  • Cameras
