Question about Electric Razor Pocket Rocket Ride-on Motorcycle
Motor won't engage. I turn the throttle and get a clicking sound, but nothing happens. We've charged the battery for about 4-6 hours, but the light stays red, never turns green. Help?!!
Posted by arballif on
  • arballif
    arballif Jul 08, 2012
    The power switch lights up, but when we turn the throttle, the controller makes a clicking sound. The motor won't turn.
youngdroop34
    New Friend:
  • 11 Answers
Sounds like the battery is bad and not taking charge.replace battery attemp again if not then check for fuel, spark and compression.then c wat happens or wats not working any motor no matter how small or big has to hv those three things to run. hope this helps.
Posted on Jul 08, 2012
1 Related Answer
reinardh
Reinard Harmse
  • 9 Answers
SOURCE: Pocket Betty throttle
It sounds like you have to replace the electric motor. Good luck!
Posted on Apr 22, 2012
1995 Isuzu Rodeo won't start all of a sudden.
Check connection battery,could be starter.
Jun 05, 2013 | Cars & Trucks
My Motorola electrify won't turn on or charge. It
maybe your battery or your phone os .... try a new battery if nothing happens... try re flash your phone
Jun 02, 2013 | Cell Phones
My LG 4G LTE won't turn on even though it has been charging for hours.
do you have a universal travel charger? and use it to charge your battery for about 4 hours. or buy a new battery.If it is not ok, your phone is in short-circuit. go to service center
Apr 15, 2013 | LG Cell Phones
2002 silverado 1500 hd won't start
When you turn the key to start does the starter engage an spin the engine ? or nothing happens .
the lights and music come on but the motor will not start when I turn the key ??????? Will not start how ?
crank - no - start or no crank no start . ????????
Feb 26, 2018 | 2002 Chevrolet Silverado 1500HD
If your valve body is stuck open or closed, would that cause your car to not turn over???
If no movement of the engine happens at all, then please check the following:
1) Battery voltage. You should have 12.5 volts and over. Try turning on the headlights and cranking. If they dim considerably, then your battery is likely flat and may need charging/replacing.
2) Battery voltage is fine, but nothing happens: Is there a clicking when you turn the key? If so, then check the starter motor. It's likely failed.
3) Battery voltage is fine, but there is no clicking when I turn the key. Check voltage to the starter motor solenoid on the top of the motor. If it is receiving power when you turn the key to crank, yet not moving/engaging, then replace it.
4) Battery is fine, but no power to starter motor and/or solenoid. Check all battery connections, leads and connections to the motor and engine body.
Nov 17, 2012 | 2006 Nissan Pathfinder 4.0
My htc incredible s won't charge, I've tried
It sounds like the charging port on your phone is broken. This could have happened a number of ways. Either by dropping your phone, putting the charger in wrong, or taking it out wrong. If you call HTC(866-449-8358) and it is still under warranty they will probably fix it for free as long as it doesn't have any water damage(http://www.ehow.com/how_4479971_check-cell-phone-water-damage.html). Otherwise you could also get a new phone.
Oct 19, 2012 | Cell Phones
My '99 saturn sl won't start. the battery has a charge, and the alternator is good, but it won't turn over.
Hi Vernon, There could be a number of different reasons why your vehicle is failing to start. The battery voltage could be dropping during start and become unable to engage the starter motor to turn the engine. You can check this by trying the key with the head lights switched on. If the lights become very dim, you'll need to check the battery, meaning clean the terminals and then try to start with a jump from another battery. If you achieve start up and it fails again the following morning, you will probably need to replace the battery. There could be a problem with the starter relay or a loose contact for the starter motor, most lik3ely the one connecting to the soliniod. It would be good to know some additional information, such as does a clicking sound come from the starter when engaged? Is there a perceptible drop in voltage output when the starter is engaged? does the enine turn at all? Try what I've suggested and if that does not solve the problem answer the questions and let me know anything else which you may think is relevant. Regards John
Nov 18, 2011 | 1999 Saturn SL
I have a 883 harley davidson sporster, was riding the bike and road over a bump and bike shut down and won't start
I'd check the battery first. I've seen the post break loose from the batteries in many Sportsters and leave them dead on the road. I've only seen this happen once on a Big Twin. Why? I have no idea. If nothing on the bike works, this may be the problem. If everything else works but it just won't start, I need more information. Does the starter engage and the engine turn over?
Steve
Aug 13, 2011 | 2000 Harley Davidson XL Sportster 883
Electric Razor Pocket Rocket Ride-on Motorcycle Logo
884 people viewed this question
Top Electric Toys Experts
Lawrence Oravetz
Mike Stager
Mike Stager
Are you an Electric Toy Expert? Answer questions, earn points and help others
