<!-- from fixya rte -->The red light on my mouse keeps on blinking - Computers & Internet
Mister Danger
  • 5,631 Answers
Get yourself a new mouse.
Posted on Jun 08, 2015
Sam R
    New Friend:
  • 43 Answers
Here's a guide;
What do the battery lights mean on my mouse? Some keyboard and mouse models feature a battery light that shows the current status of the batteries. The following table describes the different lights and states.
Light
Device Model Status Single long green blink Rechargeable Batteries are good. This occurs when batteries are first installed or every time that the device is turned on. Slow green blink Rechargeable Device is docked in the charging station and is charging properly. Steady green Rechargeable Device is docked in the charging station and does not need additional charging. Steady green Presenter Mouse (Japanese version) Laser pointer is on. Red/green blink Wireless Device is discoverable (trying to connect to the transceiver). Slow red blink Non-rechargeable Batteries are low and need to be replaced. Slow red blink Rechargeable Batteries are low and need recharging. Fast red blink Rechargeable Device is docked in the charging station, but there is a charging error.
Reasons for errors: The wrong type of battery is installed; the battery or batteries are missing; or the battery connection is bad.
Solutions: Make sure that the correct battery or batteries are installed, and are installed correctly. If necessary, remove the batteries, wipe them with a clean cloth, and reinsert them. Steady red Presenter Mouse (Standard version) Laser pointer is on.
Posted on Oct 27, 2014
The mouse keeps blinking red even though it is connected to the 1gb memory stick and the other part is connected to the mouse what does that mean please?
The mouse keeps blinking red even though it is connected to the 1 GB memory stick and the other part is connected to the mouse.
Sep 23, 2010 | Microsoft Wireless Mobile Memory Mouse...
I have a micro innovation mouse it has 2 parts the mouse has a red light how can i hook it up please
plug the transmitter into a usb port. make sure batteries are in the mouse and the switch is on. press the button on the transmitter and the red light will blink slowly. next, press the reset button on the bottom of the mouse. when the red light on the transmitter blinks fast, it has connected.
Sep 05, 2010 | Micro Innovations PD7250LSR Wireless RF...
Changed battery correctly but the on/off green light keeps blinki
you have to hit the button on the wireless base adapter as well as the one on the mouse its self
good luck and pls rate this post
Mar 23, 2010 | Logitech Wireless Access Duo Optical...
I replaced the batteries in the mouse, but the red light keeps on blinking even after setting in back in the stand.
is there a "Connect" or "sync" button on the mouse and it's receiver? Try pressing both for a few seconds then release and see if they sync back up.
Dec 30, 2009 | Logitech Cordless Mouse
HP wireless mouse problem
If it has a button on the bottom of the mouse, press and hold till it goes drk.
Hope this helps, Bud
Nov 09, 2008 | HP Wireless Optical Mouse
Not working
dear,
The small notch in usb device socket under the mouse could be malfunctioning. If you press this notch you will find the mouse red light blink. If you further try pressing this notch at some point the mouse red light comes on constantly. Thats it, hold it there and try to connect first by pressing the usb device connect switch and then the mouse connect switch. The moment the connection is made the usb device stops blinking and the red light on the mouse starts blinking. Wow, it works now. Some one might just open the mouse and fix this microswtich for a permanent solution.
regards,
dont forget to rate it
Aug 19, 2008 | Microsoft Wireless Notebook Optical Mouse...
My logitech mouse has a blinking orange light one it
had a similar problem. i took the new batteries out again and WAITED about 20 seconds before putting them back in. the red light stopped blinking.
Jul 21, 2008 | Logitech MX 600 097855036162
Mouse optico doesnt work
dear,
The small notch in usb device socket under the mouse was malfunctioning. If you press this notch you will find the mouse red light blink. If you further try pressing this notch at some point the mouse red light comes on constantly. Thats it, hold it there and try to connect first by pressing the usb device connect switch and then the mouse connect switch. The moment the connection is made the usb device stops blinking and the red light on the mouse starts blinking. Wow, it works now. Some one might just open the mouse and fix this microswtich for a permanent solution.
regards,
hope it will fix your problem
Jun 27, 2008 | Microsoft Wireless Notebook Optical Mouse...
Red light
If you're talking about the red light on the bottom of the mouse, it is needed for the mouse to track its movement. When the mouse is not being used, this red light blinks only once per second or so to save power, but once it sees movement, it will come back on.
Aug 17, 2007 | Logitech RX600 Mouse
Computers & Internet Logo
2,068 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
