Unit is charged and LED flashlight works. Also, tried putting in new AAA batteries and did not help. When powering-up, a small squelch, but not even the screen comes on. When I place the unit (turned off) into the charging cradle, the red LED on top of the radio comes on and stays on, but the LED on the charger does not come on like it used to. Nothing in the manual on the red light on top of the radio coming on when in the charger.
Your radio needs to be turned off when on the charger, and be certain you are using a rechargeable Motorola battery. The charger will not charge AAA batteries or rechargeable style AAA batteries. If the light does not illuminate on your charger, try the radio in a different charger and see if it does. This will tell you if it is the radio or the charger. One further note, you should clean your charge contacts with a pencil eraser to insure they are making good connection.
SOURCE: HX4700 will not power up
I have repaired many of the Hx4700s that appear to be dead by shorting across the "battery locked" switch. It is located on the lower right corner of the board when viewed from the back with the cover off. The switch just shorts to ground when the battery is locked in place. By flowing a small bit of solder over the two connections on the back of the switch, the iPAQ will return to life and there is no ill effect of bypassing this switch. In my opinion the switch is to fragile and poorly placed.
SOURCE: Batteries not charging
Michael Are the batteries the original power pack? this charger are disigned for work just for this batery packs only. Check if the conctas on the battery lead for dust or corrotion.
SOURCE: Battery will charge if off of radio will not charge if attached to radio
look on the battery , you sould see a 3 digit code. EG if you see a code like 458 . this means week 45 ,2008 or if it is 123. this means week 12 at 2003. The motorola batteries last up to 2 yrs. if it older than 2 years old , replaced the battery
SOURCE: hp zv 5000 won't charge battery or turn on
you need to remove and install the battery. Some times this works first try others may take a few trys. Mine does the same thing. Good luck
SOURCE: My Casio Exilim S770 won't turn on or charge
Wow I can't believe how many people this happened to. I have the same camera and is under warranty but they said would not cover the battery. I got on Ebay and purchased another battery that came with a charger and was only 12.99 for the pair. The battery is an NP20. It is not the camera or the battery it is the charger. Apparently there is a problem with the charger on this. Trust me get a new charger and the battery will charge and work. Thanks
Michael
