Model is wd8015c, if you google the seal you can see the nossle hole thingy that it leaking from I don't know why it's there no hose connects to it
SOURCE: Water Leak at vent area in door...
On this model the vent is open and shut by a wax motor. The vent should be closed tight during the entire wash cycle and the first 6 minutes of the drying cycle. Check the operation, make sure there is not a bunch of gunk restricting it. If you are handy with a meter check the resistance of the motor. It should read approx. 2100ohms. Another reason for leaking at the base is oversudzing. Also check the upper spray arm for cracks or splits shooting water into the vent area. Catriver...post back.
SOURCE: LG WM2688HM front loader is leaking water around the door seal
this may be coming from the soap dispenser and running down round the door way and to the bottom- investigate that first. otherwise the seal may be worn/ damaged and needs replacing.
SOURCE: water leak on fwd passenger side after every rain storm
If your car has a sunroof, there are drains from the front corners of the sunroof, and they drain down the sides of the windshield pillars, and then empty out on the ground.
What I would do is open the surnroof, and pour water into the front corners, and then oobserve where the water drains out. If you have a difference in water drainage between the left and the right sides, I would think that you may have loose sunroof drain. They commonly come loose at the sunroof corners. This will allow the water to pass down the windshield pillar, and onto the floor.
Also, I would check the condensate drain tube for blockage. Pull back the carpet, under the glove box, and fins a black hose that pokes thru the firewall. Pull it out, and see if it is blocked internally. If this tube is clogged, water will build up in the heater box, as the black tube is the drain for the heater box.
One of the two above solutions will cure your problem. I see both quite often.
Thanks for choosing FixYa for assistance.
SOURCE: water leak on fwd and back passenger side after every rain storm
pull your carpet up near the leak area and look for muddy body seams. it is possible one of the factory body seams are leaking- possibly in the cowl(under wipers) area, especially if it leaks when the car is sitting. there will be dirt/mud around the seams that are leaking. also you can check door seals by running the car on HIGH DEFROST with all doors and windows closed. spray around with a 50/50 soapy water solution. obviously bubbles will form around your leak.
SOURCE: water frozen in bottom of freezer. after frozen
Hi: It sounds like a clogged defrost drain. You have the hole pegged. That's where the water should go. Put your food in a cooler and unplug the refrigerator. Take a hair dryer to clear the ice from the drain hole (the one you found in the back.) Pour a warm and strong solution of water and clorox bleach through it. Use a pipe cleaner if neccessary to snake it out. Since the hole is exposed and the drain line isn't refrigerated mold can grow in it or a frozen pea can clog the line. When the clorox water hist the evaporating pan it's supposed you might smell it. It did with my GE. When the line is free your freezer will be fine. Thanks, Jeff
Is there meant to be a plug in it??
You sure of that model number/
