I am the original owner of camry xle 1998 with wet floors. In 2000 I had drivers side door seal leaking at welt. Removed old door seal and new weather strip on drivers side installed. The door panel was never wet, but wet at bottom of door where there are drain holes...slowly leaking under carpet.
In 2001 later water again. Coming from overflowing A/C evaporator-drain plugged/ tank full of debris. Removed evaporator, cleaned + drain cleaned.
In 2003, driver door seal against window rotted. Removed door panel and found leak at window belt molding at the mirror joint inside + out. Lots of mold under carpet needed to replace! Made a fuss at dealers for reacurring problem and they replaced the carpet for free.
Your A/C drain hose may be plugged. If so, the condensate from the A/C box will leak onto the floor, and eventually soak the rear carpet as well. This is a common issue. It is under the glove box, close to the passenger floor. Remove it and make sure that it is open. Alos, always run the A/C in the RECIRC mode.
Water in the trunk can be from a bad trunk seal or poorly sealed taillamp seams
Water wetting carpet at corner of bedroom/bathroom wall
Water seeping wetting carpet on floor in bedroom at corner of bedroom/bathroom wall on driver side
