Need a pass key for a motorola h300 in order to pair it with a samsung sphm 540
the pass key is 0000
With the headset power off, press and hold
the Call button for 6 to 10 seconds until the
blue indicator light turns on and remains
steadily lit. (The light will flash while you
hold the Call button.)
If the indicator light is flashing or does not
remain steadily lit, turn off the headset and
repeat step 1.
Before you can use your headset, you must
pair (link) it with your phone.
Step A - PUT HEADSET IN PAIRING MODE
Note: To turn off headset, see "Turning On and Off" on the
reverse side of this guide.
PAIR
Your Phone
Select (Menu) > Settings > Connection >
Bluetooth Link > Handsfree > Look for Devices.
The phone lists all Bluetooth devices it finds.
Select Motorola H300.
Press OK or Yes to pair (link) the handsfree
device.
Enter the passkey 0000 and press OK.
Note: Passkey cannot be changed
from 0000.
Step B - SET THE PHONE TO LOOK FOR
YOUR HEADSET
When your headset is successfully paired
how do i sync this with my katana phone by sprint???
