20 Most Recent
Motorola Mobility HS810 Consumer Headset Questions & Answers
Unable to put phone into
Most blue tooth device manufactures use the power button to set your device to discovery mode,first you must turn the power to on for your blue tooth from your phone menu,then most manufactures use the power button to put the blue toooth device into discovery mode,by holding the power button down when you turn your device on holding it for 6 to 10 seconds,usually a solid light appears on your blue tooth device,it is now in discovery mode,on your phone menu there should be an add new or search devices,once you've clicked that it should discover your blue tooth device,then you will need a pin or pairing code,Most manufactures use a factory 4 digit pin pairing code the y are as follows 0000,1234,1111,or 9999, if you have done the steps correctly the menu will say connect,press conect and you should be connected..i hope this helps
2/22/2011 5:21:18 PM •
Motorola...
Answered
on Feb 22, 2011
Hi, how can I pair up my Motorola Bluetooth HS810
On your phone, make sure bluetooth is turned on (settings, general).
While
your phone is in discovery mode, turn your bluetooth device on and put
it in discovery mode (usually you have to hold the power button for 7-10
seconds).
Your phone will find the device, and you will be
prompted to enter the devises PIN number (often 0-0-0-0). Your phone
should pair with the device then.
2/17/2011 9:12:39 AM •
Motorola...
Answered
on Feb 17, 2011
Volume is too loud
Refer to Page 7 of your User Guide and press the Volume button down.
http://www.motorola.com/mdirect/manuals/HS810_manual.pdf
12/29/2010 4:49:57 PM •
Motorola...
Answered
on Dec 29, 2010
I have a motorola HS810
not at all as the units code match them selfs to the cell phone the only thing you may need to do is change your sons code to a non matching code to your unit
best luck
please remember to rank my advice if it helps you
12/2/2010 2:28:20 AM •
Motorola...
Answered
on Dec 02, 2010
Wont find headset
Fold the mike boom to rear, push center football shaped button down for about 3 sec until it stays lit (not blinking) unfold the mike boom make sure it stays steady lit (no blinking) scan for bluetooth Walla!
2/22/2009 4:36:56 AM •
Motorola...
Answered
on Feb 22, 2009
Hi, I have a motorola
flib the mike boom to fold, press on the large center football shaped button until glows steady, then open the boom should stey stedy lit, scan for bluetooth with your divice it will receonize it!
Capt B. Ricciardi
2/22/2009 4:33:54 AM •
Motorola...
Answered
on Feb 22, 2009
Cannot pair hs810 with my razor v3
here the steps, first you have to open your BT to pairing mode by close your boom and hold the button untill the indicator light show(not flashing), when u see the light DO NOT release the button, open your boom the you can release the button after that open your phone bluetooth then choose search for device there should be your BT(HS810) on the list then pair it.
1/31/2009 6:17:55 PM •
Motorola...
Answered
on Jan 31, 2009
I can not pair my razor v3
Go to menu. Then to Connection. Click on Bluetooth link. Go to setup. Then click on find me. Then you should be able to sync your phone to his. For him to sync to you quicker, he can click on sync under connections in the menu. Then you should be able to send your pics, phonebook, the whole nine yards! The default pin to conect them is four zero's.
1/13/2009 8:35:15 PM •
Motorola...
Answered
on Jan 13, 2009
I have an hs810 motorola
Male sure before trying to find the bluetooth headset with your phone that the bluetooth headset is off. Hold down the power button until the led stays on. Then quickly use your phone to fetect the headset. If it will not detect the headset while the led is solid on, then it is not compatable with that phone! Good Luck and Thanks for using FixYa! Please rate if this was helpful or not!
1/13/2009 7:38:42 PM •
Motorola...
Answered
on Jan 13, 2009
Is this compatible with our phone?
this post is quite old but i think i'll answer it...first of all your phone must have bluetooth. to use it you must pair your phone with your bluetooth headset first. Open your bluetooth headset in pair mode and then open your phone bluetooth pair them and they will auto connect after you paired them(usually).
10/12/2008 12:39:46 AM •
Motorola...
Answered
on Oct 12, 2008
