At www.reliable-store.com get complete guide on whether to repair or not, service it, and how to repair etc, along with wiring diagrams, electrical diagrams, torque specs, error codes, everything.
SOURCE: channnel keeps flicking like your changing channels with remote
when you say flickering??? are you saying the screen goes black and comes back on?? does the sound go out at the same time and comes bag on with the pic ? Is the sound there when this happens but is distorted. Is the pic blacked out or is it greying out with lines and twisting?? Need more info please as if its blacking out and the sound goes with it it may be going into shutdown. If the pic is getting kinda greyish with it twisting and the sound is there and ditorted then the tuner could be bad
SOURCE: TV not turning on.
set is going into shutdown. what type of tv is this. lcd.. could be one of many problems.
Mine was doing that and I ordered a replacement power supply board for it and now it work. It's fairly easy to replace.
http://www.partstore.com/GetModel.aspx?MfgName=Royal+Philips+Electronics&BrandName=Philips&ModelNumber=37PF7320A37&page=16
SOURCE: Remote programing for TV after changing batteries
HOW TO PROGRAM GE Remote Control DOING CODE SEARCH
1. turn on device 2. press setup (underneath on/off) till red light stays on the take finger off the button 3. press and quickly release device button (tv,vcr,etc.) the red indicator blinds off once 4. press the on/off button (up to 300 times) until the device is to be controlled turns off the red light blinks off with each button press 5. press and release enter to install code
SOURCE: tv wont turn on
reset button is usually under setup>picture>other. however your problem may be because of the lamp. If your TV is 4-5 years old you may need to change your lamp.
