20 Most Recent
Sanyo DS19310 19" TV Questions & Answers
I've lost the remote to
Try website like Remotes.com to buy an original remote.Universal remote just don't have all the tv functions.
I am trying to hook up my dvd player to my sanyo tv
I have red, blue and green cables when I hook them up to the back to the Sanjo TV I can't get the Audio to work. She has basic cable with no cable box just a converter box that give her reception. Should I put the blue and red cable on Pr and Pb and take the green cable and put it into the video out?
Why wont my iv come on
If this is the case, nobody can predict what might have been happened to your TV. Contact any service technician. If you wish to get some details, check the site linked here.
Electro help . Pull up older posts. Check the site in '
Mosaic' view. It will make search easy.
My volume don't work
I too have the same problem but have misplaced the original converter. If you have one, try using that for volume. Even the volume button on TV will not work. Looks like your cable connection is ok. Anything else connected to this tv like PVR, ?
Ds19310 remote code
HelloYou are asking for universal remote codes for Sany I assumes, and posts this solution. Actually I didn't understand about your need. So I hereby send teh code list published by Sanyo. It doesn't contain any codes for TVs, at the email address you provided on your complaint post. Check and feel.Five digit universal remote codes for Sanyo are:10054, 10154, 10159, 11142 [codes with RCA RCR 312W universal remote control]Three digit universal remote codes are:004/ 013/ 049/ 108/ 110/ 180/ 209four digit remote codes are:0049 0097 0110 0004 0268 0012 0108 0180 OK.
I cant get my tv to turn on
Visit the site named 'Electro-help' for
more details. Check this link and
select the site. View it in 'Flip card' option, which can be selected
from the drop down box menu at the left top corner or the display window. It
will make search easy. Some times, the ads attached with each posts might help
you to find the availability of spare parts. There are more than 550 posts to
different brand TVs.
Sanyo model # ds19310 16
If you still have the Sanyo remote, you just need to press the INPUT button on the remote. The channel search and some other functions are disabled when the TV is in video/AV/game mode.
If you don't have the Sanyo remote, but you have a Universal remote which you use with the TV, look for a button labelled INPUT or SOURCE on this remote and try pressing it.
If you don't have any remote for this TV or you are using a universal remote which does not have an INPUT or SOURCE button, please reply to me from within this page for further assistance and let me know the brand and model number of any universal remote you are using. There is no option in the menu for doing this, but there a couple of methods which work on some TVs
Hope this helps.
Regards,
BElectric
Model #ds19310 only receives one
Yes it will help. Also try moving the antenna you are using to other parts of the house. I.E. near a window, that sort of thing.
I have a Sanyo 19"
I would buy a universal remote control for your tv as some won't operate without the remote control features on it.
My sanyo ds19310 is stuck
You will have to purchase a Sanyo universal remote. Then you will be able to command as you please. Thanks for asking and show a few hands of support.
I am able to turn
try to replace the cable that connects to your tv the video cable might be deffective.
I had just bought an
hi,
have someone watch the tv while you wiggle that connector around in the back while its hooked up to the vcr or cable is plugged in and channel on 3 or 4 see if you get any luck, use a little pressure to move the connector. This is a common problem. It will probably need to have the connector resoldered to the board.
jm
