Sewing Machines Logo
S
Stephanie Canty Posted on Jan 22, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can't get a 1/4" seam allowance to sew on my eden rose without jamming the bobbin for quilt piecing .
Julia Wood
Level 2:
Habit-Forming:
  • Expert 158 Answers
  • Posted on Jan 23, 2018
Julia Wood
Expert
Level 2:
Habit-Forming:
Answers
158
Questions
8
Helped
36841
Points
499
Perhaps a 1/4" seam is a bit too small for it to handle. Try a slightly larger seam allowance. On a bit of scrap fabric.
2 Related Answers
barbeedollee
  • 18 Answers
  • Posted on Jun 28, 2008
SOURCE: quilting seam allowance
When you turn your machine on it automatically sets up for a straight stitch with the needle centered. Just guide the right edge of your fabric along the line marked 15 on the throat plate and you'll have very close to a 5/8" seam. If you need more precision you can adjust your needle position to the left or the right by using the stitch width and mirror setting buttons.
i_luv_2239
Jacquelyn Gipson
  • 23 Answers
  • Posted on Jul 31, 2014
SOURCE: extra piece of thread in bobbin compartment after
Its normal. Learn how to clean machine.
1helpful
Ran over pin. Broke needle, replaced it. Was jammed pretty good. Cleaned out bobbin compartment. Dogs look good, but motor doesn't run. Lights come on, stitch card functions. Viking husqvarna Quilt
Oooh, ouch!!! Were you able to get all of the needle pieces out of the machine? Unfortunately, it may have knocked the machine out of time or bent/damaged some internal mechanism necessitating professional service.
In the future, instead of placing pins horizontally across the seam line, align them parallel with the seam edge--far enough away to clear the presser foot. Sew slower and remove the pins before they get to the presser foot. Broken needles can be dangerous to you and the machine--as you already know.
2answers
What foot should i use for quilting. i have a brother vx-1435
Your best option will be a "walking" or "even feed" foot. Your Brother dealer should have them in stock.
1helpful
2answers
I have a Husqvarna Eden Rose 250m. Where can I find replacement parts.... Such as the extra spool holder? I have searched the internet to no avail. My dealer went out of business.
go to the Husqvarna Viking website to locate the nearest Viking dealer. Viking does not allow their dealers to sell parts and accessories over the internet
1helpful
While trying to free motion quilt on my juki TL-98Q, it becomes very hard to move the quilt whenever I come to a seam. I have already turned the pressure foot dial to the lightest setting. I simply
I have never used a machine to free motion quilt. That said, I have had issues sewing over thick seams. Since your machine runs smoothly otherwise... I think it is the thickness of the seamed area that is causing your problem. It may be too late but you could try trimming your seams so the layers fabric graduate to full thickness. Or you could use a chop stick or popcicle stick to press down on the thickness as you guide the machine over the seam. I also suggest that you Fan your seam allowances where your blocks come together. You can see how that is done here. http://www.allpeoplequilt.com/videos/v/62207505/machine-minute-bulky-intersections-fanning-seam-allowances.htm
Mar 19, 2014 • Juki TL-98Q
4helpful
My Janome 6600 is having a hard time going over seams during piecing of a quilt.
try changing the needle
also try to adjust the tension on the presser foot bar, if your machine has one
1helpful
How do I quilt on my 9000
Your question is a little vague... Put simply, here is how to make a quilt. Start by putting 2 pieces of material (good sides together) and sew a 1/4 inch seam. Keep on adding pieces until you have a quilt.
2answers
Extra piece of thread in bobbin compartment after sewing a few pieces. Its a brand new machine, with drop in bobbin. I am sewing on minke fabric with a quilt batting inbetween. I tried adjusting various...
I am not sure I am following your explanation.
Set the tensions back to the factory setting.
Refer to the manual for threading instructions.
Always thread a sewing machine with the presser foot up.
Make sure the bobbin is inserted so the thread is feeding from the bobbin spool in the correct order and through the proper guides.
Hand-walk the needle down and back up while holding onto the end of the thread.
Pull up the bobbin thread and take both threads under the presser foot and to the back of the machine.
Always take the threads toward the back of the machine when you begin a new seam.
This may, or may not be contributing to the problem, but the materials you are sewing shed a lot of lint and the bobbin case, shuttle and surrounding area new frequent cleaning.
I WOULD LIKE TO TRY MACHINE QUILTING WITH MY ROSE MACHINE. DO I NEED A SPECIAL FOOT ATTACHMENT OR COMPUTER CARD?
If you want to piece quilts, I recommend a 1/4" piecing foot. Husqvarna make several different types that may be used on the Rose.
If you want a dual feed or walking foot, check out the new Interchangeable Dual Feed foot.
You only use card with the Rose for embroidery, which you can do on a quilt, but not necessary.
Quilting seam allowance
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
