20 Most Recent Singer Stylist 7258 Electric Sewing Machine Questions & Answers
HAAA!!! Me, too!! I just got the same code. I actually took off all the stuff to clean it (glad I did too because after a whole week of sewing on it straight, it was hella filthy!), I still couldn't get it to work. The answer is in the Singer FAQ website (http://www.singerco.com/support/frequently-asked-questions). Your button hole lever has been bumped. It is just to the left of the the needle bar. I just pulled mine all the way down, then pushed it all the way back up. No more E7!!!! Color me happy for sure!
Singer Stylist... | Answered on Apr 17, 2019
sadly you have burnt out the motor or foot control . and the only fix is to replace whatever you burnt up . take it to a repair center locally .
Singer Stylist... | Answered on Jun 16, 2016
Which stitch are you using? As far as I can tell, the Stylist 7258 only allows you to change the needle position for straight stitches. If the machine is set to Pattern 00, press the right or left buttons from the 4 arrow keys in the manual setting arrows until the needle is in the desired position.
For all other stitches, the left/right arrows adjust the stitch width. This is described on page 30 (in English) of the manual. You can download the manual from the product page under the support tab: http://www.singerco.com/products/2101/7258-stylist#type-support . The direct link to the manual is http://www.singerco.com/uploads/download/4951b452e963a8fe1dd1fd83fbac68a35df8cf19.pdf .
I hope this helps.
Singer Stylist... | Answered on May 25, 2016
the needle position is up tight in the holder and no where else
the cut away bit of the needle faces the bobbin case hook and the groove in the needle faces the end of the machine and gives clearance for the thread to pass through the material
from your description and what you did, the needle /hook timing needs adjusting as it is out
turn the machine over by hand as in sewing and watch the position of the eye of the needle and the bobbin case hook
just as the needle starts to move up, the hook should be just above the eye of the needle at the edge of the needle
The adjustment is by loosing off the screw on the vertical shaft at the end of the machine that is attached to an arm that moves the needle up and down and move that bit up or down until the needle is positioned correctly to the hook
tighten up the screw
next is to check the needle tension is not too tight
workshop manuals are available on line in pdf version or take it to a sewing machine repair shop for a proper diagnosis
Singer Stylist... | Answered on May 12, 2016
Try this:
http://www.fixya.com/support/t18116338-reset_e7_error_message
Contact Singer Support for assistance.
Singer Stylist... | Answered on Jan 05, 2016
this link is for the manual go to page 32 ,it sounds like you have it on button hole stitch witch goes in revers, you need to press button hole off switch.
http://www.singerco.com/uploads/download/617_7258-instruction-manual.pdf
Singer Stylist... | Answered on Oct 24, 2012
Order the service manual directly from Singer.
Singer Sewing... | Answered 57 minutes ago
The needle plate shouldn't be hard to put back into place. Make sure that you have it aligned correctly and that the needle is fully up. When you removed the plate, you should have slid it forward slightly and then lifted the plate up. Do this in reverse: bring the plate down and level very close to where it fits over the feed dogs. Then push it forward. Next secure the two screws. See page 72 in the manual, https://www.singer.com/sites/default/files/product_manual/SINGER%207469%20and%207469Q%20Sewing%20Machine.pdf .
I hope this helps.
Singer Sewing... | Answered 2 days ago
Singer Stylist 7258 Electric Sewing Machine Logo
18 questions posted
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Kelley Buchanan
Kelley Buchanan
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Singer Sewing Machines
Most Popular Question
bougth singer 7258 in usa 120v turned in
  • Sewing Machines
