20 Most Recent
Husqvarna Rose Questions & Answers
Loaded 3D Embroidery software on
1st try another usb port
2nd uninstall the software and plug the device in only after you have reinstalled the software and you are asked to plug it in. If it doesn't ask then install the software first and try again.
You can also right click on my computer and select manage.
then on the left side of the window select device manager, unplug and plug back the usb dongle and see if any devices appear or disappear also note any yellow ! marks. you may have to press the scan for new hardware button or right click on the window to scan for hardware changes.
My Viking Rose sewing machine starts and stops and
The Rose has a sensor on the presser bar assembly that is giving you the grief. The machine thinkss the presser foot is in the raised position.There is a small metal flat spring that has gone bad and causing the error. Find an autorized service center to repair the problem.
Feed dog won't come back up after embroidery is
You must slide the feed dog up/down switch over (consult your manual).
If you slide the switch over, the feed dogs will not come up. It is only when the machine makes a full rotation that the mechanism engages and the feed dogs return to the sewing position.
If the feed dogs will still not raise, then you will need to take it to your dealer.
Feed dog wont come up high enough to sew
try this and see if it will work for youWhen you set the switch for the feed dogs in the up position turn the handwheel 1 complete revolution and see if they come up
What does the flashing circled E on the info
The flashing E means the design is either too big for the sewing field limit (about 3.93 x 3.93") or not centered. From the sound of your description, most likely the design is not centered. Check the design size in software and center it before transferring to the card.
Sewing machines
Try this link for free manual for the Viking Rose machine -
http://new.husqvarnaviking.com/SiteMedia/Products/Machines/Support/Rose_605_manual_EN.pdf
There are 2 models called 'Rose'. The original Rose is the manual above. The newer Rose is called the Eden Rose. You can find most user manuals for Viking machines on their website. Here's how:
website:
http://www.husqvarnaviking.com/us
Go to bottom of page on righthand side and click on 'Machine Updates'.
If your machine is not listed click on 'All Machines"
Scroll down until you find your machine and click on the name of your machine.
The link should take you to a page with a picture of your machine and a link to Download the manual which is a PDF file.
Good luck.
How do I change the bulb in my rose?
Your user manual should explain how in detail with pictures. It is sometimes hard to get the bulb out without breaking it. But try this -
With machine unplugged/power off lay machine on it's back. Locate the light bulb. You probably have a little rubber device in your accessory case that has a suction cup on each end. One end will say In and the other will say Out. Use the suction cup to grab the bulb and pull straight out. Use the other end to install the new bulb in the machine.
If you need a manual - Try this link for free manual for the Viking Rose machine -
website:
Good luck.
Need manual for rose
website:
Good luck.
