Televison & Video Logo
k
karen foster Posted on Sep 21, 2017
PBS. date and time THE WALL - Televison & Video
I am in South Paris, Me., and have lost the picture on PBS since yesterday. Blank screen. Second time this has happened. I rely on PBS for the Sunday night programs!
I love PBS too. Double check all connections sometimes connections come loose, get dirty or corroded. If Antenna, check wiring.
What time does Miranda, teacher of eccentrics, come on PBS?
Check the listings in your local service provider PBS schedules differ around the country
6answers
I would like to activate pbs
If you like to activate PBS on your Roku 3, and then do the following activation steps one by one.
1. Go to the Roku home screen and type "PBS" on Search Box.
2. And Select the PBS from the search list.
4. Once loading is completed click "Go to Channels".
5. Copy the seven-digit number from the displayed screen.
untitled6-qizfbljhmmqbswp3ibggqyqd-3-20.png6. Then open the web browser from any one of the devices.
7. Go to the pbs.org/activate and enter the activation code here.
8-qizfbljhmmqbswp3ibggqyqd-3-27.png8. Click Continue for the PBS Activation.
For more information about the Roku Activation or PBS activation call us at 1-855-804-1313 or visit us at https://www.rokucodelink.com.
Oct 04, 2016 • Roku 3
2helpful
3answers
How to activate PBS using Amazon Firestick on my Tablet?
Just opened with this URL: http://www.pbs.org/activate
Enter the code in the box that says Activation Code, and hit continue.
CAn nolonger watch videos from the Nova Site via PBS.org
maybe you need to update Flash Player...or the drivers in your PC..
No PBS signal
drpends on were you live they all ave not converted over give it time
1helpful
How to set the clock on vcr/dvd.
Make sure the antenna//cable TV connections are correct. Channels are set. If this unit is connected to a cable/satellite box, select the local PBS station on them to set the clock automatically.
There's an Auto Clock Setting. "This Unit can set the time and date automatically by reffering to a PBS station.". But I never had to do that, I just went to Setup and it already knew what the date and time was.
"Note: The clock may set itself automatically after you connect the antenna/cable signal and plug in the power cord. Only the analog PBS channel signal is effective for auto clock setting. The unit receives the clock data at 12:00 A.M./P.M. from the PBS channel when the power is off.
1 Press [SETUP] and use the up and down arrows to select "General Setting", then press OK.
"General Setting" menu will appear.
2. Use up and down arrows to select "Clock" then press OK.
"Clock" menu will appear.
3. Use up and down arrows to select "Auto Clock Setting", then press OK.
4. Use up and down arrows to select "Auto" then press OK.
5 Press SETUP to exit.
6. Press STANDBY-ON to turn off the unit.
This unit will search for the time only when the power is off. Leave it off for several minutes to give this unit time to set the clock.
If the unit chooses an incorrect PBS channel, set the PBS channel manually by following the steps below:
1. Select "Manual" at step 4, then press OK.
2. Use [the number buttons] or up and down arrows to enter your PBS channel number, then press OK.
3. Press SETUP and turn off the unit.
If this doesn't work, let me know and I'll type up the instructions for what to do if you need to actually set the clock manually.
Mathis...
According to Time Warner cable I no longer have TV Guide On Screen because the PBS piggy back signal is no longer being sent. Apparently, PBS is getting ready for HDTV. I live in Wilmington NC and we went...
PBS in my area says that my cable provider, Time Warner is no longer using the analog signal that contains TV Guide On Screen info. They did this to prepare for digital in Feb. Time Warner says they are waiting for Gemstar/Macrovision to provide a method for the On Screen feature to work. My source at PBS reckons there are over 25,000 cable card TV's that may lose this On Screen Guide. Apparently there is no legal requirement for TV Guide or your cable provider to send the guide.
Users may want to try and contact TV-Guide/Gemstar/Macrovision directly at their toll free number
1-800-386-7380. This may not be a solution but it may be a consolation for users wanting to know why they have lost their TV Guide On -Screen.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
