We have a Sony XBR that suddenly had a vertical line appear throught the screen. A couple of days...
(More)
We have a Sony XBR that suddenly had a vertical line appear throught the screen. A couple of days later another appeared. I searched this site before and found a possible solution with the ribbon cables being loose, but I can't find the answer again. Any suggestions?
connect PC to TV and switch to external output mode and get no picture (sound okay). lower left...
(More)
connect PC to TV and switch to external output mode and get no picture (sound okay). lower left states "invalid format"
KDL-46S3000 Canada 6" horizontal section of trhe screen is OK From the top just below the...
(More)
KDL-46S3000 Canada 6" horizontal section of trhe screen is OK From the top just below the 6" sction, is another section(separated by a 1/2 mil. or so, there are three other sections completing the screen that are also separated from each other with diferent luminosity, and from the center to the left gets darker and sort of oscilating
I have a high deph phillips big screen, and it does not get a signal for NBC or CBS. We have a VIZIO...
(More)
I have a high deph phillips big screen, and it does not get a signal for NBC or CBS. We have a VIZIO upstairs that is connected to the same antana, and it gets those channels just fine.
In trying to remove a DVD/VCR unit and connect directly to the cable box I removed the cable feed...
(More)
In trying to remove a DVD/VCR unit and connect directly to the cable box I removed the cable feed from the back of the wall mounted set (Bravia KB series). I connected directly to the cable box then replugged the cable line back into the TV. Color was off, so I reconnected the DVD/VCR exectly the way it was before. Still the color was off. I tried to do a factory reset, following the manuel using the remote but it does nothing. How could the color have gone wrong simply by unplugging the cable feed from the set?
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked....
written by stiv0
Vizio Tv's have an extra menu that contains factory settings which you can change or fix should you have a problem with your TV.
Here's how to...
written by TechNerd
If an LCD TV has sound but no picture do the following: Use the source button to ensure that source is not set to the wrong input.
Try unplugging...
written by ginko
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal
is...
written by ginko
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
The codes are at this website:( http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml ) Just put the...
All Polaroid flat panel I have a FLM-3203 32 inch LCD. After reading so many posts on replacing the to 10v caps I decided to do this to mine. After...
written by prowler21
When you have a damaged or unrepairable television it may seem like a total loss and ready for the trash. Instead of trashing the television, why not...
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's...
by wikihow
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output...
by wikihow
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
